So I finally got everything installed and can connect to WG login to Majormud, but can't do anything.
I know this might be something simple I'm overlooking. (new to this)
When I hit (e) to enter the realm, I get the line
"Please select your race... ? for help"
but that's it, I don't get the list of races, I can't select anything.
If anyone can give some ideas or advice would love it.
Semi-working board
Re: Semi-working board
Only thing I can really say to check is your ansi setting, if you installed globals =a.
Also are you getting locked or can you x out? I would look at reinstall mud, or try an offline recovery. Can you enter other modules say teleconference?
I checked ansi settings, seems to be working/setup right.
I can hit (x) but thats it, I can't get help info using (?) though, just a blank space.
If I can't figure out soon I'll just do the reinstall just trying to avoid that right now.
It was, I reinstalled everything and its working now.syntax wrote:sounds like empty databases to me.
Now I'm having trouble with the addons, says I don't have them, but I have the codes entered, MOD 1-3 are working fine but can't access anything past that.
I figured it out thank you everyone for your help.
Another question, how would I edit the race stats (increase by like 20 each)?
You need an editor to do it. Nightmare is the standard one to use. Check out the forum on here for it.
