BTRIEVE CREATE ERROR 25 ON FILE "galssc2.dat"
Necrosaro420
Post by Necrosaro420 »
So FINALLY found a working copy of Trade Wars 2002. Can get the board to load up fine with it etc, yet it crashes when I try to go into the game from the bbs menu. Anywho, now every time i start WG up, I get this popup:
Any ideas? Thanks
Drizzt
Re: BTRIEVE CREATE ERROR 25 ON FILE "galssc2.dat"
Post by Drizzt »
I was getting that to until I restarted the machine
LordEvil
Post by LordEvil »
Ctrl-Alt-Del, stop wgserver.exe and w32mkde.exe, restart server. This seems to work for a few btrieve errors.
sharphead
Post by sharphead »
Necrosaro420 wrote:So FINALLY found a working copy of Trade Wars 2002. Can get the board to load up fine with it etc, yet it crashes when I try to go into the game from the bbs menu. Anywho, now every time i start WG up, I get this popup:
Any ideas? Thanks
Your Worldgroup is running as a service and is currently active (online).
Start > Control Panel > Administrative Tools > Services
and look for "WGS Executable" it may say "Started" - go ahead and stop it and make sure it's set to Manual.
Now you can manually start the server via Start Menu again.
:shock: Stock MajorMUD - 128 ports - 24x7x365 - telnet:bbs.thenexusbbs.com | http://www.thenexusbbs.com :shock:
Larsen1906
Post by Larsen1906 »
Any ideas? Thanks
Where is it? :)
telnet tdrbbs.ddns.net
