A new stock realm is launching on Friday, April 28th at 6PM EST on the GreaterMUD board!
telnet to: greatermud.com Port 23 -- IP Address if domain not working: 217.180.196.241
Choose option 3 on the Realm Menu
The realm will be stock MajorMUD content running on the always-improving GreaterMUD engine. As this will be the stock content, limited items and first kill drops are in place. No additional content mods will be applied to the realm aside from a few normal fixes such as shop markups.
Some basic settings information:
Gear drops to the ground on death as normal (This realm will NOT be using GMUD PvE's corpse container system)
3 level pvp range ( a compromise to allow both pve and pvp styles of play in one realm)
15% HP loss hang penalty
Evil points fade at a rate of 1 per hour (This happens live on GreaterMUD, with no need to wait for cleanup to realize EP losses)
1 character per PERSON/I.P. with NO EXCEPTIONS. This includes remote control like Teamviewer
Please familiarize yourself with the full realm rules here:
http://greatermud.com/forums/index.php? ... n#msg37883
Winterhawk has also graciously created a Greater MegaMUD installer package customized for GMUD stock content which is available for download here:
http://greatermud.com/forums/index.php? ... attach=104
The realm is currently up and available for people to set up MegaMUDs and play until it resets on Friday, April 28th at 6pm EST.
See you there!
New GreaterMUD Stock Realm Launches Friday 4/28 6PM EST
Re: New GreaterMUD Stock Realm Launches Friday 4/28 6PM EST
I would like to play on greatermud but it doesn't want to connect telnet to port 23
greatermud.com:23
How can i get hooked up to do some mud gaming there?
are you guys using a different port?
beast12125
greatermud.com:23
beast12125
Looks like they changed to paradigm mate, you can check the advertisements in this forum its a few posts below this onebeast12125 wrote: Thu Dec 26, 2024 8:00 pm I would like to play on greatermud but it doesn't want to connect telnet to port 23
greatermud.com:23
beast12125
Have no idea how long ago they changed the name.
Thanks for the information about Paradigm mud.
Looks like the telnet address is mud.paramud.com on port 23
Thanks a lot.
beast12125
Thanks a lot.
beast12125
