Greater MUD Reset
Posted: Thu Sep 08, 2022 4:26 pm
by rhalin
Greetings mudders.
Greater MUD is due to reset again. PVP on 9/17 and PVE on 10/1.
It's the dawn of a new era for GreaterMUD. We're transitioning to an updated code base and new servers. Any old accounts will need to be recreated.
The guys have been hard at work. 8000+ new rooms, hundreds of new mobs, items, and quests. Complete release notes to follow.
We're currently enjoying a bit of a soft launch to test out new servers and new code base. Feel free to come in, get an account set up, and pal around for a few days before the LIVE resets kick in.
Addr: 217.180.196.241:23
PVE: Option 1 (will run through 9/30)
PVP: Option 2 (will run through 9/16)
The greatermud.com DNS will be switched to the new servers on 9/16, the day before the PVP reset.
Hope to see some of y'all in the realm.
Thanks,
Rhalin
Re: Greater MUD Reset
Posted: Fri Sep 09, 2022 9:40 pm
Ever going to open source it?
Posted: Thu Sep 15, 2022 5:54 pm
by Greater
rhalin wrote: Thu Sep 08, 2022 4:26 pm Greetings mudders.
Rhalin was able to get all the old account data moved to the new server, so if you have an old account you should still be able to use it to log in. If necessary you may just create a new account instead. All bans remain in effect.
Production realms are currently tagged in the menu with their reset date and times:
PVP - 9/17 @ Noon EST
PVE - 10/1 @ Noon EST
Once reset, each realm will be tagged with a "Last Reset" date.
Temporary realms will run until shortly before reset time in order for you to get MegaMUDs set up and fine tuned.
The GreaterMUD forums are up in a limited, read-only capacity as a resource for reset information and downloads. Forum logins will not work for now. Here are a few shortcuts:
GreaterMUD Explorer + Export
http://217.180.196.241/forums/index.php ... n#msg37759
Greater MegaMUD by Winterhawk (paths and database updated for GreaterMUD
http://217.180.196.241/forums/index.php ... n#msg37757
2022 GreaterMUD Changelog
http://217.180.196.241/forums/index.php ... n#msg37756
Rules and Reset Information
http://217.180.196.241/forums/index.php ... n#msg37755
Telnet to: 217.180.196.241 port 23. See you for the resets at Noon EST on 9/17 (PVP) and 10/1 (PVE)
Posted: Sat Sep 17, 2022 10:17 am
by rhalin
DNS hasn't propegatted yet, reset for PVP is still noon today, but you'll need to use the IP.
Thanks,
Rhalin
Posted: Mon Sep 26, 2022 3:05 pm
by rhalin
DNS has propagated and PVP is up and running! come join the massacre.
Also, PVE reset has been delayed to 10/8 due to the pending Hurricane situation.
Posted: Sat Oct 08, 2022 11:34 am
by Greater
PVE resets today at noon EST.
greatermud.com port 23
Come have fun!
