Level 68 Dwarf Priest
Level 72 Dwarf Ninja
Level 58 Dwarf Druid
Currently making 2.5 mil/hr
Is there anywhere else I could loop these three to make more?
I need scripting suggestions...
Moderator: BearFather
Re: I need scripting suggestions...
Level 72 Dwarf Missy
Level 65 HOG Ranger
Level 65 HOG Cleric
I was trying to loop dark elf commoners but i get rounded sometimes... so cant do that yet... I'm also looking for suggestions.
Level 65 HOG Ranger
Level 65 HOG Cleric
You both have not mention which realm your in. So guess give you stock ideas
DB:
Take the druid and put him in massive web, the other two pair up and hit storm giants.
SL:
Take the Mish and put him in like stone giants while evil, and take the other two and same thing storm giants.
These are both assuming a stock realm and have your pick of places.
DB:
SL:
BearFather wrote: Tue Nov 10, 2020 6:00 am You both have not mention which realm your in. So guess give you stock ideas
DB:
SL:
i mentioned dark elf commoners and getting rounded so I assumed those weren't in stock realm... i apologize for not being more specific
Well edited opens up a huge amount of spots. Like crystal dragons, ice tower(pelal), volcanic wastelands, rothe pins.
If you can get your roomers to the rothe pits in menzo, mad exp.
If crystal dragons are open really good exp with an north and south loop.
Volcanic might be too low of exp right now but poision immunity is helpful.
A single guy can pull 1mil a level at ice tower, not hard esp with cold resist.
You got neth sewers but would also need help getting there.
Sorry didn't catch the dark-elf line, I normally read these when first waking up.
- goodriddance
other ideas: inner thay forest, farmland on the way to the thay village, red and blue crystal worms on the way to crystal dragons
you may be best suited to splitting your party into 2 + 1 - sending 1 char somewhere alone and 2 together.
for ninja/priest/druid it's a little tough to split (easier if 1 toon is super beefy w/some heals, like a cleric). i'd probably recommend setting the druid up solo and gearing him for combat - so swing dual hammers and rhel/rgen/mend as needed - and then have the ninja/priest party in the crystal worms. don't have anyone cast spells for damage, resting for mana is too inefficient - just swing weapons and heal.
just my 2c!
just my 2c!
Currently I'm making 3 mil/hr in storm giants and 2.4 mil/hr in crystal solo... is that decent for their levels?
