MegaMud Blues
rhikdavis
MegaMud Blues
Post by rhikdavis »
Hi guys, I'd like to run Mega off of a flashdrive. Everything seemed to install fine, but when I try to run it, I get cannot create c:\capture and then a message about a dir entry file....I assume its trying to write something to the C drive instead of the flashdrive.....Anyway I can redirect it to write to the flashdrive?...
Re: MegaMud Blues
Check the ini settings, it most likely pointing to c drive in there esp if you copied over the folder from another drive.
rhikdavis
Re: MegaMud Blues
Post by rhikdavis »
I don't see any files with an ini suffix? Where are those?
thanks
Re: MegaMud Blues
they will be in MegaMud/Chars the files in this dir is your ini for your toons.
rhikdavis
Re: MegaMud Blues
Post by rhikdavis »
Thanks. All the bbs ini files are in the chars directory....I don't know what ini that Mega is trying to find.....Isnt there a general ini file for megamud itself...telling it whether to open a char up upon launch? I think I just need to turn that off if I can find the file.
rhikdavis
Re: MegaMud Blues
Post by rhikdavis »
Ok, so it works when I "run as administrator". Go figure.
I forgot that I had to run it like that.
Thanks BF.
R
Re: MegaMud Blues
Your main INI is in C:\Users\(user)\AppData\Local\VirtualStore\Windows\
And glad you got it working again.
