Stealth Quest
Stealth Quest
From MMB:
Note - to do this quest you must be:
Level 25 Missionary
Level 20 Ninja
Level 20 Thief
Level 25 Bard
Level 25 Gypsy
Level 20 Ranger
Level 27 Mystic
  1. Kill the master assassin in the black fort and "push panel"
  2. Head to the 2nd master assassin, watch out for the traps:
    1 2        4        6 7
     *        3*5        *
       *-*-*-*-P-*-*-*-*       P = push panel (monster regen room)
    1. Take path 5 to the gate and pull lever
    2. Return to push panel room
    3. Take path 7 to the gate and pull lever
    4. Return to push panel room
    5. Take path 2 to the end of the path
    6. Search north
    7. Follow path to gate and pick or bash open gate
      vHead north and defeat Master Assassin again
  3. Be sure NOT to kill the dying master assassin! ask it "secret" and you will get supernatual stealth.
From MudVille:
Not doable by everone, this repeatable quest gives you the ability to sneak even better than ever before. There is really not much to this one. Check this table to see if you can do this one:
Bard 25
Gypsy 25
Missionary 25
Mystic 27
Ninja 20
Ranger 20
Thief 20
In a Nutshell:
  1. Go to the black fortress
  2. Go to the Master Assassin's room and kill all monsters in the room
  3. Move panel
  4. Grab this map
  5. Run like your armour is on fire through the tunnels, pulling the levers
  6. Kill the 2nd Master Assassin
  7. Ask dying secret
  8. Work your way back down to the room where you entered these tunnels.
  9. Move panel to exit.
From MudCentral:
To complete this quest, you must be one of the following:
Level 25 Missionary
Level 20 Ninja
Level 20 Thief
Level 25 Bard
Level 25 Gypsy
level 20 Ranger
Level 27 Mystic
  1. Goto Master Assassin in Black Fort
  2. Defeat Master Assassin
  3. Push Panel
    Darkened Tunnels
    Beware of traps in this area
    1 2        4        6 7
     *        3*5        *
    6. Search north
    8. Head north and defeat Master Assassin again
  4. Greet dying
  5. Ask dying secret
    To Return
                M Master Assassin
        *>*<*<*-*-*>*>*>*       < = trap when heading west
       /        #        \      > = trap when heading east
      *       *-*-*       *     # = trap
    12 11   14  9  13    8 10
  6. Take any gate back but the one you came through.
You have completed the stealth quest, you will get 0 exp and the ability of supernatural stealth! (less chance of breaking sneak)
