Give Codec of Twinks to other accounts? + Edit Keys
- Necrosaro420
Is there a way to give codec of twinks to other accounts except for the main sysop account? Will be helpful in editing to be able to give several characters it.
- Necrosaro420
Re: Give Codec of Twinks to other accounts?
Figured it out. Think it was the SUPER key.
But I do have another question. What file is it stored in, that you can edit keys for Mud? Since I can add the SUPER key, maybe change/hex that to CODEC key or something?
Re: Give Codec of Twinks to other accounts? + Edit Keys
You need wccmmud.ini file. Search on here for it, there's a whole thread talking about how to set it up.
- Necrosaro420
BearFather wrote:You need wccmmud.ini file. Search on here for it, there's a whole thread talking about how to set it up.
Yeah, but I mean like, what file is the actual key stored in? I know the ini is to give certain abilities etc. I am talking about which majormud file states that the Super/Master key is specifically needed to use coded of twinks.
As in which dll? I would thing it would be wccmmud.dll that would have it. Or you talking about what setting? That would be in security and auditing settings if there is one, I don't recall ever seeing it.
EDIT:
You could check in wccmmud.h but you would need to open it up in a hex editor.
Also wccmmud.msg is all the settings that you would find in the WG menu's.
EDIT:
