setup @home for new bosses, how to do @alive for stock?
I got the @home working for the bot I have in mmud for the bosses I have added, cant find anything that explains how to do it for the stock bosses unless its already there and I dont know how to do. thanks
Re: setup @home for new bosses, how to do @alive for stock?
for new bosses i used @alive rather than @home that way @home and @alive work via broadcast channel 1 so change your m/r to @alive rather than @home hope that helps
Ok I changed it to @alive and thats still working for the non stock bosses, I gave my guy full remotes and everything on the bot and do @home adult red dragon and I still get the command invalid so its not even trying to check the room. Im at a loss as I never used this before and its my first time trying to set it up. thanks for the help
n/m got it working, put megamud on my windows vm and stopped using it in linux, and didnt add the @alive back yet and the @home is working. Hopefully it doesnt make the @home stop working once I put @alive back in for non stock bosses. thanks for the help
wonder why not working in linux mine works perfectly in linux??? oh well least its getting to work for ya
Could check out goslink, it has bot abils built in and it's java based so works on all OS's.
http://www.mudinfo.net/viewtopic.php?f=47&t=1506
