HELP! Betrieve error 87 wgskey2.dat
I don't hav emy 2nd mud live yet, but I just started getting these errors when trying to startup WG server.
Re: HELP! Betrieve error 87 wgskey2.dat
You get these errors a lot when you dont have files= setting high enough in config.sys esp when running multiple muds. Now most OS these days don't have a config.sys, so will have to search on how to up files in your OS. You can also try to disable modules to reduce the files needed. But running multiple muds require higher settings.
If this doesn't help with this issue WGSkey2 sounds like some sort of file dealing with reg keys but this is a complete shot in the dark.
If you goggle Betreive error 87 you will find find the error code page that will actuay give you what the issues is.
I kept getting random Btrieve errors almost immediately after installing WorldGroup... pSQL v9 fixed it up, check the guide.. not sure how to get the license for the windows server permanent though, someone else can maybe help with that. Good luck
Did you set your reg settings as indicated here?
http://www.mudinfo.net/viewtopic.php?f= ... ings#p4345
These two help?:
http://www.mudinfo.net/viewtopic.php?f= ... r+87#p2641
http://www.mudinfo.net/viewtopic.php?f= ... r+87#p3296
These two help?:
