Sys Goto and Sys Map
iofhua
Post by iofhua »
How do I give players the ability to use sys goto and sys map?
There is a thread somewhere here that says I need to edit wccmud.ini and add the proper keys to the abilities there - but I can't find it. I searched the WGSERV folder and it turned up nothing. Could someone point me to the right place?
Re: Sys Goto and Sys Map
iofhua
Post by iofhua »
So this needs to be in wccmud.ini
EXP_IN_TOPGANG=1
BLANK_LASTNAME_ALLOWED=1
SYS_MAP_KEY=
SYS_GOTO_KEY=
SYS_LIGHTNING_KEY=SYSOP
SYS_STATUS_KEY=SYSOP
SYS_ADDLIFE_KEY=SYSOP
SYS_RETRAIN_KEY=SYSOP
SYS_ALIGNMENT_KEY=SYSOP
SYS_EDITEVIL_KEY=SYSOP
SYS_SPEAK_KEY=SYSOP
SYS_LISTUSER_KEY=SYSOP
SYS_LISTLIMIT_KEY=SYSOP
SYS_USERINFO_KEY=SYSOP
SYS_JAIL_KEY=SYSOP
SYS_CHANGE_KEY=SYSOP
SYS_CLEARSUICIDE_KEY=SYSOP
SYS_REPORT_KEY=SYSOP
SYS_TOPTEN_KEY=SYSOP
SYS_DISBAND_KEY=SYSOP
CODEC_OF_TWINKS=78
DISABLE_GOSSIP=GIDIOT
That helps. But I need to know where wccmud.ini is located. I don't see it in the WGSERV folder. Do I need to create it?
When I log into my board as sysop, there is an option in the majormud sysop menu to edit it. Is that the only way? I would prefer not to type it in line by line, if possible. If I could find the file and just copy/paste into it that would make things a lot easier.
can create by using notepad also make sure the keys match what keys is set in wg setup
