How to setup Dialsoft?
iofhua
Post by iofhua »
I have installed Worldgroup 3.30 and Dialsoft Control 4.0 (for Worldgroup 3.x). The setup completed without any problems - now where do I find it? I don't see an entry for it in Security & Accounting, General Setup, or Hardware Setup. I have logged into my BBS as Sysop and don't see an entry for it there.
I don't see an entry for it in Offline Utilities. However if I run WGSDMOD (disable or reenable selected modules) in Offline Utilities, Dialsoft CONTROL shows up as a thing I could disable, if I wanted to. That's the only entry for Dialsoft I've been able to find in all of Worldgroup so far.
Does anyone have more experience with Dialsoft that could lend me a hand? I just want to get in there and setup IP restrictions (2 accounts per IP).
Thanks for your help.
iofhua
Re: How to setup Dialsoft?
Post by iofhua »
Nevermind, I figured it out. I had to run "wgsrunmt" and add the entry for dialsoft at the main menu of the BBS.
iofhua
Post by iofhua »
So under TCP/IP Control in Dialsoft, would I enter:
IP Control: *.*.*.*
IP Scope: 1 - 255
Max Number of Users from this IP: 2
To set up a limit of 2 accounts per IP? Or would this create a maximum of 2 accounts from any IP? (limiting my BBS to two active accounts)
*Is there an easy way to set up a two account per IP restriction in this? So far it looks like you have to add a separate rule for each possible IP. That's inconvenient, just a lot.
iofhua
Post by iofhua »
