Quest Flags go away on recovery
DarkwoodBBS
Post by DarkwoodBBS »
When I run an offline recovery, mudrev quest flags using Ability 200 or higher seem to be removed from characters. Is there any way to prevent this?
telnet://darkwood.ddns.net -- Mudrev with fixed and enhanced content, 25 level PVP
Information: http://www.mudinfo.net/viewforum.php?f=55
Re: Quest Flags go away on recovery
it's one of the cracks in the dll that needs to be made
edit: actually, to the wccmmutl.exe file
Do you know what to look for to crack this?
I would love to raise the numbers myself.
I do. I have a crack for what says to be for "v1.11o and v1.11p-beta13" but the v1.11p-final has a different CRC. Also tested the crack on the v1.11o and v1.11p-beta13 wccmmutl.exe files and while it says it patched it, it also says it failed the crc check. So I'm trying to verify it all for v1.11p final.
So I just verified it. There is a file called " MajorMUD_v1.11o-v1.11p-b13_AbilityStripCrack.exe "
You run it and it says --
MajorMUD v1.11o & v1.11p-beta13
*Offline Ability Strip Fix"
this will patch wccmmutl.exe to stop it from stripping abilities > 190.
this hack will only work on the v1.11o and v1.11p-beta13 wccmmutl.exe file.  it will appear to apply correctly to other versions but not work.
(v1.11p-beta13 was the latest wccmmutl.exe at the time of this patch creation)
I just verified that it also works on the v1.11p final wccmmutl.exe.
It changes...
CODE:00403C9E                 cmp     [ebp+ebx*2+var_C2], 0BEh
to...
CODE:00403C9E                 cmp     [ebp+ebx*2+var_C2], 7FFFh
0BEh => 190
7FFFh => 32767
Hex editor offset 3CA6
3CA6:	BE => FF
3CA7:	00 => 7F
@offset 3C9E through 3CA7
stock:
6681BC5D3EFFFFFFBE00
cracked:
6681BC5D3EFFFFFFFF7F
I'm not finding that file in google, so I will have to bust out the hex editor and give it a whirl. Thanks, I wish I knew this a year ago, much better then trying to shove all my quest flags into lower numbers.
Here
MajorMUD_wccmmutl.exe-AbilityStripCrack-works on v1.11o,v1.11p-b13,v1.11p.7z
(21.72 KiB) Downloaded 536 times
DarkwoodBBS
Thank you i will try this out
my antivirus reports the crack is a virus
Bloodrock wrote:my antivirus reports the crack is a virus
I'm not saying it's clean, but most programs that edit a file the way this does is considered a virus by the more "robust" antivirus software. I would google the the message your antivirus thinks it is.
