SYS MAP ONLY ?
rhipcity
SYS MAP ONLY ?
Post by rhipcity »
I was trolling through the old threads and i cant seem to find anyone discussing the option for sys map only.
Do any of you GURU's happen to know where i can find info about that?
or would someone be kind enough to go over that with me?
-rhip
Re: SYS MAP ONLY ?
gotta edit the wccmmud.ini file the key has to be same as one in your mmud setup
here is a copy of my wccmmud.ini file top line of file has to be blank
EXP_IN_TOPGANG=1
BLANK_LASTNAME_ALLOWED=1
SYS_MAP_KEY=NORMAL or whatever your key in mud setup is
SYS_GOTO_KEY=NORMAL or change to SYSOP
SYS_LIGHTNING_KEY=SYSOP
SYS_STATUS_KEY=SYSOP
SYS_ADDLIFE_KEY=SYSOP
SYS_RETRAIN_KEY=SYSOP
SYS_ALIGNMENT_KEY=SYSOP
SYS_EDITEVIL_KEY=SYSOP
SYS_SPEAK_KEY=SYSOP
SYS_LISTUSER_KEY=SYSOP
SYS_LISTLIMIT_KEY=SYSOP
SYS_USERINFO_KEY=SYSOP
SYS_JAIL_KEY=SYSOP
SYS_CHANGE_KEY=SYSOP
SYS_CLEARSUICIDE_KEY=SYSOP
SYS_REPORT_KEY=SYSOP
SYS_TOPTEN_KEY=SYSOP
SYS_DISBAND_KEY=SYSOP
CODEC_OF_TWINKS=78
DISABLE_GOSSIP=GIDIOT
rhipcity
Re: SYS MAP ONLY ?
Post by rhipcity »
Thank you Bloodrock, this helped me greatly..
ive used mudinfo.net for its entire existence, im so glad its still here.
rhipcity
Re: SYS MAP ONLY ?
Post by rhipcity »
I went to room 238 map 1
I read from a few sources that the command, "LEARN SPELL" would apply the sysop spells?
doesnt seem to be working
Re: SYS MAP ONLY ?
its learnspell not learn spell and has to be magical warrior witchies do not get it
rhipcity
Re: SYS MAP ONLY ?
Post by rhipcity »
perfect, thank you
Joker
Re: SYS MAP ONLY ?
Post by Joker »
rhipcity wrote:I went to room 238 map 1
So, do I understand correctly, that you have an active player with Sysop powers, using Sysop spells in a PVP-enabled realm? In my opinion, this is not good for business.
rhipcity
Re: SYS MAP ONLY ?
Post by rhipcity »
You assume incorrectly, I have a Sysop account, with sysop spells, who doesnt play or get experience, but thanks for being completely irrational about the situation.
