For a number of reasons to include me opening the realm with little notice and the horrible lag caused by my faulty Virtual Server provider, this realm is dead. There's 3 players. So I took a vote and people want to see it reset. Just to clarify, the game that is resetting is the current No-Dupe game (option N on the Menu). The other realm will remain open for business.
The game will open on Saturday, March 21 at 7:00 PM ET (4:00 PM PT); Telnet is MMUD.US
First, and most important, my server is now hosted in Dallas through a new datacenter. It's been running very smooth since the transition. If the lag scared you away last time, come out and try the server again.
Game Basics:
2 Accounts Permitted (1 main / 1 dupe); you can still have 2 accounts for the other realm as well.
PVP will be 15 levels
Gang Houses will require 1,000,000 EXP
Sys Map will be enabled
Lives will cost 1 Runic
3 stacked levels permitted
10-20% HP Hangup Penalty
Cleanup will occur at 12:00 Noon ET with no expressed warning
Game Enhancements/Edits:
Chainmail will have a level restriction of level 12
Scalemail will have a level restriction of level 15
Platemail will have a level restriction of level 20
Limited 1 items are increased to Limited 3
Limited 3 items are increased to Limited 5
Bash, the attack ability, has been removed from the game
Golden Locket will be removed from the game on opening day
Low-level mobs such as Newhaven mobs, Slums, Sewers, and Graveyard have increased cash drops
Thrag HP has been doubled and his accuracy increased
Mino Champion HP has been doubled and his accuracy increased
Orc-heads no longer delete at maintenance if in your inventory
Lair Mod has been installed to increase spawn rate and spawn numbers for popular scripting areas
GJR are available at the Curio Shop for 1 Platinum
Most spell ingredients drop 100% (Spider Leg, Thrag's Eye, etc)
Base stats increased by 40
If you haven't noticed by now, the intent is to significantly slow down the ability for Warriors, Clerics, Paladins, and Witchunters from dominating the first 72 hours of the game. Everyone should have an equal shot at the low-level bosses and the resulting gear they drop.
Since the server will remain active for the other game, feel free to setup your accounts prior to the opening.
Enjoy!
CJT
MMUD.US realm is re-resetting 3/21/2015 @ 7:00 PM ET
Re: MMUD.US realm is re-resetting 3/21/2015 @ 7:00 PM ET
A lot of good ideas here, including the armor level restrictions. Should be an interesting realm. Looking forward to trying it out.
Updated the realm information. Added a hangup penalty and modified base stats. Changes are highlighted in Red.
