changes or added things to lostways mud updated 3-1-2015
edited area as of 7-7-2014 dragontooth hills ne of rhu 2-960 - 2-1102
control room 2-812 set to 140 atributes 4 11 8 0 812 group 4 lair hod spell
new area blue drag stats baby blue dragon
exp 7000 index=35 game limit=0 active 0 regen time 0 type solo
alignment chaotic evil gender it ac 62 dr 6 hitpoints 450
hp regen 50 m.r. 75 follow % 70 charm lvl 9999 charm resist 9999
bs defence 25 energy 1000
campground area added map 1 rooms 3463-3521
3486 and 3487 added for battlemage
10019 for next textblock 3500 for next new message
with lockers 1-3558 with lazy woods 1-3620
lvl 10 questors added to junkyard shop#3 new equip added to junkyard shop#4 added 7-17-2014
group 15 min index 39 max index 42 grey dragons copied from blue dragons added 8-2-2014
added map 7 room 1728-1998 great dragons room 1998 edited to cyan dragons min index 43 max index 46 8-8-2014
added map 1 room 3621-3745 8-14-2014 in the gob cave barracks on way to thrag and werewolf
orc knight ac 70 dr 6 group 27 index 50 hp's 500 8-29-2014
orc general ac 70 dr 6 group 27 index 51 hp's 550 8-29-2014
orc king added map 1 room 3746-3749 for orc king
added #514 trex and items 3227-3232 and rooms map7 room 1999 to 2002 for trex also 3235 head of king and added gold lifestealer
added 520 521 523 for dynasaurs in dragon tooth hills rooms 819-932 map 2 new items for trex 3227-3232 set trex to 48 hour regen time
adjusted 2020-2023 monsters to hit more added 3236 glowing sabre 9-28-2014
set lazywoods to be low lvl area with group 1 mobs map 1 rooms 3559-3620
campground at this time has ivory golems should change to a low lvl area changed
item 331 added to game edited stats was in but not active
created rooms 3347-3673 map 17 outside to east of arlysia pond and forest
added monster 2024 giant crocodile for arlysia pond from giant crocodile #391
added monster 2025 battlemage for arlysia forest from hill giant chieftan #647
added map 1 room 3750-3772 north of cave bear map 1 room 2156
added monster 2026 cave bear exp of 110 gr1 index2 from original cave bear #80
added monster 2027 grand wizard new boss to room 1447 map 1 from mad wizard #129
added monster 2028 shadowmage for arlysia forest
edited rooms down in fungus forest for more regen
added abandened house map 1 rooms 3773-3838 off of map 1 room 61
added 2029 ghost gr 10 ind 7 from #308
added 2030 ghoul gr 10 ind 100 from #16 put in room 3846
added 2031 great thrag map 1 room 3847 from #59 go path from golems room
added 42 new lockers south of khaz map 6 rooms 3290-3346
deleted map 1 rooms 3335 3348-3446 might have been something forgotten or never implimented
added map 6 rooms 3347-3401 with new 2032 golden monstrosity from #374 10-23-2014
added 3226 titanium belt
added alder chest to 1st alignment quest #974 and added addability 4=maxdamage raised exp to 350,000
added serpent armour #3237-3241 lvl 110
added another ruby quest to orc king room useing abil 188 and textblock 10004 from 4702
added another ruby quest to banshee room useing abil 189 and textblock 10005 with 3488 for it being 50,000 exp
added map 1 rooms 3348-3435 at map 1 room 1747 darkwood forest with werewolf from #127 (rooms used were deleted see above)
moved map 7 rooms 1532-1998 to lava fields off of map 7 room 921 used a go crack text 2454 1 8380 66 room parameters
parameter for go path is text 8339 0 8340 66
added a 2nd drop of #499 golden chalice to hellion and #1306 nature tap sold at aged titans spell shop champion of blood regen set to 24 hours
added map 1 rooms 3848-4066 called rooftops for above silvermere 11-2-2014
added 2034 giant bat from #71 for rooftops gr 10 index 9 and 2035 raven from #187
made map 1 room 4003 upper curio shop on rooftops put trex stuff for sale in it and titanium belt and earrings
added map 7 rooms 2003-2156 for new cyclops area off of map 7 room 609 2036 gr 10 ind 10 new cyclops from #131
added map 7 rooms 2164-2372 assassins encampment 2157-2163 fungus forest trail off of map 7 room 471
textblock 10007 added for new sit throne using abil 191 set for lvl 25
added map 7 rooms 2373-2374 assassin throne tent for new sit throne quest
textblock 10008 added for new sit throne using abil 192 set for lvl 35
added map 7 rooms 2375-2377 cyclops throne room for new sit throne quest
added 2037 master cyclops from #131 ac 85 dr 13 hp 1200 hpregen 60 removed its drops added 5 plat to money drop exp 350,000
added 2038 queen assassin from #178 ac 75 dr 9 hp 940 hpregen 50 exp 218,000 both gr 10 ind 100 added message 3491 for queen
added 2039 dark assassin from #1103 ac 40 dr 6 hp 750 hpregen 25 exp 17,500 gr 10 ind 11
added map 7 rooms 2378-2438 for new little swamp house
added map 16 rooms 2893-2925 off map 16 room 7 to tasloi village go crack
fixed rooms in new orc area that were messed up and added more lair rooms in dw forest and gob cave and bandit keep
added 2040 from 614 exp 12500 and 2041 from 615 exp 14500 adjusted hp's hpregen and hits set to gr 10 index 12 and 13
added map 16 rooms 2926-3000 off of map 16 room 1421 northern tasloi village
added map 3 rooms 789-990 off of map 16 room 646 new barren hills for lvl 55 and up
added 2042 hill giant rat from #647 gr 10 index 14 added message 3492 and 3493
added map 3 rooms 991-1199 for darkened forest
added 2043 red griffon from 721 and 2044 from 719 gr 10 ind 15
adjusted heavy bone mace hit 11-29 mag2 negate confusion
added witchhunter gear #3242-3247 sold at upper curio shop
added 2045 high druid queen from #122 to map 1 room 2419 exp 150,000 3494 and 3495 as new messages
added another 55 to all stats for races
added 2046 black orc king from #482 3496 as new message and 3248 diamond belt from #211 map 9 room 500
expanded white dragon area from map 15 room 2063 with a go path added map 15 rooms 2332-2409
added 2047 from #406 kobold queen and added map 6 room 3402 with go path
added 1 ac .5 dr and 1 max damage to fingerbone bracelet
adjusted monsters hp's in obf was set way to high and ac/dr
added map 1 rooms 4067-4081 for new ganghouse and cyan keys 3249 gh #10 off of map 1 room 36
added map 1 rooms 4082-4097 for new ganghouse and brown keys 3250 gh #10 off of map 1 room 84
added map 1 rooms 4098-4112 for new ganghouse and auburn keys 3251 gh #10 off of map 1 room 90
fixed a few rooms added forks and dens junctions and entrances as room markers map 2 rooms 819 859 920 map 7 room 2002
renamed trex area to ancient valley renamed upper dragontown to dragontown cliff
redid map so will not go into valley from dragon teeth hills
added exit n in map 1 room 3904 goes to arlysia town square map 17 room 2269 renamed to Aylysia Town Square
added exit s in map 1 room 3904 goes to sleazy shopkeeper map 8 room 486
added new ganghouse and hazel keys 3252 gh #9 off of map 1 room 2502
added new ganghouse and lime keys 3253 gh #9 off of map 1 room 2463 for both edited cleared fields area into 2 gh's
edit area by gnaj the creator adding more lairs for scripting
renamed orc king room to chamber of orc king map 1 room 3749
put spell 1285 and 1287 in temple shop added a 3rd normal combat to hill giant rat
added maneregen to all earrings fixed magely cloak to natural added abil 165 to spider and plasma gear to raise spell damage
added abil 165 to ruby mask added #3254 golden mask sold in silvermere jewelery shop
added 3255 from #423 golden bracers added 165 and 145 to copper cross
added 3256 serpentclaw staff mag5 from #264 adjusted some weapons to be 1 handed so can wear copper cross #741 #354 #264
added #3257 silver shoes from #45 4.5 ac 2 dr with abils 165-3 145-3 36-5 13-5 70-5
added new area under queen ant map 9 room 717 using go crack map 9 1433-1547
added 2048 from 483 workerant group 10 index 16
added #3258 cyan fighter eyeglasses min lvl 130 also added alterspelldamage and manaregen to all glasses
added map 3 rooms 1200-1212 added parameter item #942 1610 1611 0 for mine pass at map 3 room 1212
added map 3 rooms 1213-1328 barren tunnels and barren mine shaft
added new class wizard #16 exp% 110 bard-2 chainmail all weapons quest 10 weapon #3259 wizard mace
added wizard spirit #2049 to map 1 room 3335 which was added to crypt off 1424 to nw going to 1429
adjusted meditate quest minlv 24 and smash minlv 24 and the other quests adding wizard hopefully it all worked
==================================== priest spells ===================================
added 2048 scroll of angelic halo for 5th quest spell #1098 added 2049 scroll of divine healing for 5th quest spell #1059
added 2050 scroll of exalted word for 5th quest spell #1005 added 2051 scroll of benediction for 5th quest spell #1060
added 2052 scroll of dark transfusion for 5th quest spell #1061 added 2053 scroll of tainted word for 5th quest spell #1081
added 2054 scroll of balanced word for 5th quest spell #1096 added 2055 scroll of balanced sight for 5th quest spell #1099
added 2056 scroll of infernal darkness for 5th quest spell #1102 made map 1 room 3902 priest spell shop #251 for lvl 50 spells
============================================= mage spells =====================================================================
added 2057 scroll of manashield spell #1004 added 2058 scroll of necromantic bolt spell #1008
added 2059 scroll of chain lightning spell #1018 added 2060 scroll of prismatic beam spell #1038
added 2061 scroll of bladed sphere spell #1041 added 2062 scroll of protective shell spell #1046
added 2063 scroll of hellstorm spell #1057 added 2064 scroll of comet spell #1063 added 2065 scroll of prismatic blast spell #1074
made map 1 room 3903 mage spell shop #252 for lvl 50 spells
============================================= druid spells =====================================================================
added 2066 scroll of frozen spike spell #1003 added 2067 scroll of spore coud spell #1026 added 2068 scroll of glacial mist spell #1042
added 2069 scroll of close woundes spell #1043 added 2070 scroll of boulder spell #1047 added 2071 scroll of inferno spell #1048
added 2072 scroll of dark plague spell #1056 added 2073 scroll of barbskin spell #1062 added 2058 scroll of earthbind spell #1112
added 2074 scroll of ice shield spell #1379 added 2075 scroll of fire shield spell #1380
made map 1 room 3900 druid spell shop #253 for lvl 50 spells
adjust guardian golems regen to 50 hrs
=============================================== New quests =======================================================
spirit quest for lvl 11
from textblock 80 added link to 10006 added message 3489 from 3488 in turn was from 3387
and 3490 from 541
tb 80
Well done young one!
tb 81
quest:80
tb 82
The %s greets you with a bow, saying "Welcome young one. Thy travels have brought thee far,
to find me in this cursed tomb where I am bound. The dark one was cruel indeed to keep my
spirit in this plane after we were vanquished, but even in defeat there can be hope. I
have little left to offer, save my experiences fighting the unnamed one. My skill is thine
to learn from, and I would gladly train thee to the next level of advancement.
One more thing can I offer you: seek the old one in the heart of the
darkenwood, he alone lived through the Great Wars, and he alone has mastery
enough to provide thee with the necessary learning you shall surely need in
the future." For an extra reward ask me QUEST
tb 10006
minlevel 10 541:failability 190:giveability 190 1:checkability 190 1:testability 190 1:addexp 50000
:message 3490:message 542:message 543:message 3489:addability 58 1:addability 70 2
message 3489
<For completing quest, you gain 50,000 experience points!>
message 3490
The spirit smiles, as a shimmering glow surrounds you!
%s speaks to the spirit, and is surrounded in a shimmering light!
giovanni quest lvl 25
added lvl 25 quest to giovanni is a copy of smash quest but gives ability 87 speed 1 used tb 10009-10018 and message 3497-3499
and adds 5,000 exp uses message 2640
ask giovanni test then heads then return
faerie queen quest lvl 25
added 2050 faerie queen for new quest copied from mudrev abil 193 used tb 10019-10025 message 3500
added spells 2033 and 2034 used by quickling lord added items 3260 bracelet and 3261 key
adjusted quickling lord regen to 4 hrs
ask queen services then go kill quickling lord get bracelet of haste and 10,000,000 exp
amazon battle master quest lvl 45
quest copy from mudrev abil 194 used tb 10026-10032 message 3501
added spells 2035 and 2036 used by hill giant chieftan added item 3266 key and used 3254 golden mask
ask master task then go kill hill giant chieftan get golden mask and 40,000,000 exp
oik the innkeeper lvl 75
quest copy from mudrev abil 195 used tb 10033-10039 message 3502
added spells 2037 and 2038 used by mammoth rot worm added item 3268 key and 3267 platinum mask
ask master task then go kill mammoth rot worm get platinum mask and 55,000,000 exp
added map 6 rooms 3404-3471 off of map 6 room 1238 lava tube sallies
added map 1 rooms 4114-4138 for grey ganghouse silvermere and 3262 grey key gh6
added map 1 rooms 4139-4174 for purple ganghouse silvermere and 3263 purple key gh6
added map 6 rooms 3473-3509 for tan ganghouse khaz and 3264 tan key gh5
added map 6 rooms 3510-3555 for indescent ganghouse khaz and 3265 indescent key gh5
added 3267 platinum mask lvl 75 gonna use for a new quest
to date next room for map 1 is 4175 for map 7 is room 2438 for map 17 is 3674 for map 6 is 3472 for map 16 is 3001
next room for map 3 is 1213 next room for map 15 is 2410 next room for map 9 is 1458 map 16 room 5000 start of obsidian fort
go crack text 2454 1 8380 66 room parameters parameter for go path is text 8339 0 8340 66 parameter for mine pass item 942 1610 1611 0
