RetroMod
RetroMod
Author: Chupon (YahooIM: sunstone triad, Email: sunstonetriad at yahoo)
Created: 8/23/2005
Base Mud Version: v1.11o
Description--
I unchanged a lot of the (changes) that i feel jaded a lot of good mud items and ideas. I i also added a new item from the gibbering mage and introduced a new version of the ethereal chakram to the game, Enjoy. All changes are split up to be individually installed, so they wont change any other values.
v1.0 -- 08/22/2005:
- Released
v1.1 -- 08/23/2005:
- Fixes and Additions
----------- New In 1.1 -----------
Added Many Lair rooms to lost city, the southern most area starts with amazons
moves to amazons and warriors, guards are in the barracks, and shaman are near the top of the map
by the elder's quarters etc.
swamp boots are not level restricted "Again" If you want to try to make it to the troll at
a level < 30 you are able to.
The spell "cloud of poison #377 is now a POISON spell again"
added lair rooms to filthy encampment (map 3 544-558, ogre mages are only present in bonfire room)
New item 2049 "band of the ogre magi" dropped by ogre mages (mon #297 1%)
min level 20
7 enc
.5/1 ac
10 mana regen
+20 spell alter spell dmg
-4 accy
+2 max dmg
magical 5
New item 2050 "crude iron buckler" dropped off hobgoblin (mon #294 1%)
70 enc
level 20 restricted
3 max dmg
-1 accy
2.6/1 ac
409 Spectral Knight
can be hit by any weapon mag 3+
Upgraded spectral sword as well since nobody ever uses it, 7-23 magical 3 (+20 mag res)
1012 angelic hunter now drops nexus blade (the weapon he uses) 10%
Amazon Battle Master 656 - Regen time 2 hrs 1750000 exp 2500 hps hits hard drops stuff
stone chest 50%
ethereal chakram 15%
ntap scroll 50%
1204 ethereal chakram
magic 4 level 35
11-28 dmg
1950 speed
Casts comet 5% 20-80
3 crits 25 mag res, 1 handed bladed
Scaled lantern #1233 is now a special worn nowhere item (dont have to use it to provide light)
652-657 Now worth exp again (amazons) upped ntap drop to 5% from shamans
1089-1092 now worth exp again (snake pit snakes)
417-428 (dwarves worth exp again)
285-291 (woodelves worth exp again and worth a lot more based on metro making them much harder)
566 (rakshasha sage drops cobra earrings 25% and papyrus 15% now)
183 974 978 985 991 (young red,white,green,blue,black dragons now drop hides 5% instead of 1%)
237 gnoll chieftan drops oak chests now at 15%
1191 stone javelin back to 1400 speed, also hit magic 4 so witchies can use again
gibbering mage drops a new item
2048 - Cracked opal rod 20%
Stats are:
12-24 dmg
+4 accuracy
-3 crits
2/1 ac
-25 illu
Magical +4
Level 35
1handed blunt
1500 speed
Casts suck the life 15% (Spell #787)
+30 mana regen
+20 sc
Negates 256, 286 Solid fog and mystic mist. (useable by mage and mystic)
RetroMod_v1.1.zip
(592.98 KiB) Downloaded 537 times
