PacificBBS Now Up! Fresh Mud, Fresh Board!
JaginBlack
Post by JaginBlack »
BBS Info
•Name of BBS: PacificBBS
•Address of BBS: telnet://www.pacific-it.com
Sysop e-mail address sysop0101@gmail.com
•Price: Free
•Cleanup/Shutdown Times: 3AM Pacific time
•Are nightly backups made: Yes/Full Server
•WG Version: 3.30
•Validation required: no
•Type of Connection: Business Class 50mb down 10mb up.
•Number of accounts you can have: 5 characters per IP
Dats available at https://drive.google.com/file/d/0Bx3Uad ... sp=sharing
Fix List - https://drive.google.com/file/d/0Bx3Uad ... sp=sharing
•Version Running: v1.11p
•Scripting Allowed: Yes
•PvP Allowed: no
•PvP level difference: n/a
•Death Pile raiding: No
•Sys Commands (& which ones): Sys goto and Sys Map at level 1.
•Level Stack allowed: 16
•Training Setup (Max Level, Etc): Stock for not until player base requests this.
•Age of realm: About 7 weeks.
•New Classes: No - Whitchy's can wear plate now. Thieves have been buffed up.
•New Races: No However I have added +50 to all racial max stats to make for CP usage updated help files.
•New Items: I have fixed the slot issues with masks. There is a couple new items.
•New Areas: No
•Playing SySop: Yes.
•Playing Mudop(s): Yes.
•Death HP: -2000
•Exp. Multi/Exp Tables Lowered: No
•Limited Items: Limited items are no longer limited.
•Item Drop %: They have been raised a little bit.
Rules: No flaming or Drama dont care dont want to hear it.
No comments based on race, sexual orientation, or creed.
No Ganghouse/DeathPile robbing.
Rules above are subject to change based upon polling. 1 warning then your toast. We play to have fun not cause drama.
JaginBlack
Re: PacificBBS Now Up! Fresh Mud, Fresh Board!
The healbot is fully set up with alignment changes, retraining, and healing for those who are in need. Gold jewel rings will be given out free of charge to new characters and dupes. Log in and check it out! We need more players so if your looking for a new realm give us a try!
Jagin Black
Sysop
JaginBlack
New update just installed today! Check it out, and join us!
JaginBlack
Patch day! Woot! ... log in and check out the board. Good stuff happening!
JaginBlack
Due to demand, I have raised the dupe limit to 5 per person. For all you out there that are playing on the same IP and want to log on I will set you up so you can still play.
Thanks,
Jagin Black
Sysop
iofhua
Post by iofhua »
Any idea when the realm is coming back up?
