EntConn tragically went down in mid-2011 when the long-time sysop Mike Lunn died. In accordance with what very well may have been one of his last wishes, EntConn2 is started as a mirror board with some progressive tweaks to allow other users have a chance to get limited items, regain experience that was lost due to older dat files implemented, and a trainer to allow training to very high levels. I hope this BBS will continue to be a realm where people like want join up and continue to enjoy the arguments, friendships, and neutralities amongst each other as well as keeping the mudding alive. It's the mmudders that make up a great realm.
As mentioned above dat files have been implemented on this board from EntConn which means that EntConn2 is not a reset at all. If any of you played on EntConn before and can't remember your BBS ID please let me know via email and I will assist you, usually within the same day. If you do remember your BBS ID just logon and type new to create a new account. Enter the BBS ID exactly as you had before on EntConn and choose whatever password you want to use. BBS ID's are case sensitive when matching it up to your majormud character. I will need to give you the correct key to access MajorMud but it will happen within the same day.
New accounts are welcome as well so if you haven't played on EntConn before that's okay. Please feel free to give this board a try and see what you think. There are plenty high level characters to help you out with quests and other things.
My email is entconn2sysop@gmail.com
I am dedicated to keeping this board up and running. I'm running on a very stable internet link with a dedicated server just for WG and MajorMud. Only system updates and anything that pertains to MajorMud will occur on this PC.
Below are the specifics for EntConn2:
Address: entconn2.com
Port: 23
Time Zone: Mountain Standard Time
Rules:
-No hoarding limited items. If not using it pass it on to someone else.
-Inactive players' accounts will either be deleted or given to someone else (inactivity time still to be determined)
-No Spamming
MajorMud Settings:
Version Running: P
Scripting Allowed: Of course
Dupes Allowed: 3
PvP Allowed: No
Death Pile raiding: Don't do it
Sys Commands: Sys goto's and Maps
Level Stack allowed: 10
Max attainable Level: 250 (Universal Trainer for now)
Playing Sysop: Yes
Playing Mudop(s): To be determined
Death HP: -10000
Limited Items: 3x
Item Drop %: Stock
Monster and Boss EXP: 3x (Limited time only)
Cleanup: 5 am MST
EntConn's mirrored board up and running
Re: EntConn's mirrored board up and running
Wow, I almost threw up a little reading that. So you stole dats from a dead man and ripped off his BBS name and gave yourself and your friends the highest level chars that were on there. BRAVO. Did you even KNOW Mike, because I did, and I really doubt he would have been okay with that. And a pirated version of mud no less. Wow, talk about low. I'm sure he's turning in his grave right now. Clap clap - let the scum rule the world!
Is the realm down for maintenance? I haven't been able to connect for about a day now.
*EDIT: Nevermind. Realm just came back up.
Itching from withdrawal here... give us an update or eta please?
