What files does NMR need?
Zero
Post by Zero »
Me again, with another quick question. I wasn't able to get multi-mud working on my machine, but really I only wanted it so I could have a stock realm that I could look at with NMR for how things worked. Alternatively, I figure I can just install NMR on my main machine if I know which files I need to copy over. Not going to do any edits, just want to be able to open for informational purposes.
TLDR: Is it just the WCC*.* files that are needed for NMR to work? Or would I need some others too (no editing planned on this machine, just viewing.)
Re: What files does NMR need?
You would need to have the btrieve engine installed in order for it to be able to open the database files in the back-end. But yes, just the wcc*.* files are needed beyond that.
edit: you could install this for the engine side of it: http://www.mudinfo.net/viewtopic.php?f=44&t=1185
Zero
Post by Zero »
Alright. Thanks again for your help, Syntax!
