I made a Walkthrough on how to link your WG board. WLINK is working again and an updated DLL for it is available. Here is the site for the walkthrough.
http://hatedreality.homeunix.net/projec ... ldlink.htm
Questions about it.
Q: i tested it with my test realm got it all set thou don't understand the day editing forget which one but got 1 day set but when i try the other 6 days everytime i get the ip and hit return or arrow keys it goes back to none
A: The addy will automatically be added. OK from main menu hit W that will take you to the dialer. than hit S (schedule configuration) Hit e (edit phones). that will take you into where to put the addy. After you add it to the list there is no need to add it to each day. It will be the first Ip on the call list. You can also use the web interface to do it, it makes it a lot easier. to do that bring your board up and use http://yourboard/worldlink-scheduler for example HR's is http://hatedreality.homeunix.net:50/worldlink-scheduler, the login is the same as your name and d pword on the board. After you add it to initial list, you do not need to add it to each day. It will be the first on each day. To go to next day save the one, To move to next time use the up and down arrows, space bar will delete the line you are on such as start time put in time, than use the down arrow, put in stop time, than use down arrows and save. The web interface from web browser also works well when doing it.
Q: When I open up regedt, HKEY_LOCAL_MACHINE, SOFTWARE, Btrieve Technologies, Microkernel Workstation Engine, Version 6.15, is not there. Only Btrieve Technologies and no options to set like you wrote on your page, Dave
A: It will looks like this, if WG installed, it will not run unless btrieve is installed here is a pic of where you can find it: http://hatedreality.homeunix.net/projects/Capture.PNG
Side Note ### Email is also working again, it just requires some slight editing, static ip and a permanent domain name.
- Board index MajorMUD Forums Worldgroup and Editing Questions
- Search
- It is currently Mon Oct 13, 2025 1:31 pm
- All times are UTC-04:00
How to Link Your Board
Return to “Worldgroup and Editing Questions”
Jump to
- Content
- ↳ Quests
- ↳ Alignment
- ↳ Status Enhancement
- ↳ Ability Quests
- ↳ Item Quests
- ↳ Specific Race/Class Quests
- ↳ Other Quests
- ↳ Quest Flags
- ↳ Maps and Paths
- ↳ Phantom's v1.11n Maps
- ↳ Phantom's v1.11i Maps
- ↳ Downloads
- ↳ Database Viewers/Utilities
- ↳ Other Utilities
- ↳ Scripting Programs
- ↳ MajorMUD Explorer
- ↳ Nightmare Redux
- ↳ Other Pages (Scripting suggestions, Ganghouse information)
- MajorMUD Forums
- ↳ MajorMUD
- ↳ Worldgroup and Editing Questions
- ↳ User Created Add-Ons & MODs
- ↳ Captures
- ↳ MudRev
- ↳ MUD Humor and Player Stories
- MajorMUD Development
- ↳ MudBot
- ↳ MegaMUD - ProjectOrion
- ↳ ReMud
- ↳ TurboTwo
- General Forums
- ↳ General Discussion
- ↳ Mudinfo.net
- BBS Forums
- ↳ Advertisements
- ↳ Bear's BBS
- ↳ ClassicMUD
- ↳ Darkwood BBS
