Gang House COMPLETE Pack
Looking for a complete drag and drop solution to the gang house files. Thought I had this nipped, but appears all of my gang house rooms (fixed the stores) are producing an error.
Any help appreciated.
Re: Gang House COMPLETE Pack
This should be a full collection of the MajorMUD HSE files I use on ODS BBS, including the one thats named incorrectly...
http://ods.ods.net/MajorMUD_HSE_FILES_ODSBBS.zip
Should be 134 HSE files total.
-Matthew
-Matthew
MegaMUD BBS (ODS BBS)
Operation DataStorm BBS
http://bbs.MegaMUD.com
http://ods.ods.net
~ Since 1987 ~
http://ods.ods.net
~ Since 1987 ~
Just rehosting via these forums to ensure they're available if ODS ever decides to close the doors.
- Attachments
- (39.74 KiB) Downloaded 1735 times
Closing the doors after 25 years? NEVER! Possibly re-inventing them coming up here.
Might finally be using the megamud.com domain name I've had for years and renaming the BBS to something a little more muddy...
http://ods.ods.net
~ Since 1987 ~
http://ods.ods.net
~ Since 1987 ~
If this gets added to a realm where gang houses are already in use. Does it wipe out everything in the rooms? Basically, should the inventory of the gang houses be removed before applying this?
Nope not needed. These are just txt files for the room descriptions. If you have custom desc made up for the houses those will be lost.
The link for the file is busted. Does anyone have this file they can share?
The link above works for me.Bodhi wrote:The link for the file is busted. Does anyone have this file they can share?
The second post with ods link is broke. But the 4th post by cjt is has a good link to download.
