Euphoria BBS
BBS Advertisements. Post about your new/existing board.
Euphoria BBS
A few of my friends are getting back into the game again so I am putting up our old board again (fresh resets). Figured I'd open it up to all.
Launched Sunday, 9/1/2024 @ 9AM ET
Address: euphoria.mudinfo.net
Port: 8888
Two realms: MudRev realm and a Stock-ish realm (details below). MudRev is mudrev, mostly, with loyal items. The stock-ish realm is close to stock, but with quality of life improvements and some small additions.
Maximum of 6 connections to the board per IP address.
Full Distro (MegaMUD and MME installs plus pre-configured MegaMUD and BBS instance files):
https://drive.google.com/file/d/15MBOoT ... sp=sharing
Stock-ish MME: https://drive.google.com/file/d/15YNaWe ... sp=sharing
MudRev MME: https://drive.google.com/file/d/15_WzdP ... sp=sharing
Euphoria Stock-Ish Realm Edits
  • base (unchanged) races and classes
  • 2x monster and quest exp
  • no limited items
  • all wearable items + keys are loyal (don't drop on death)
  • max boss regen @ 48 hours, a few reduced to 12
  • weapon, armour, scroll, and chest drop rates set to minimum of 20%
  • reading glasses changed to eyes (from worn)
  • phoenix feather changed to worn (from neck)
  • fallen angel and hydra nerfed into reason
  • sys gotos and sys map enabled
  • PVP is disabled (both realms)
  • As of Feb 2025: Level 66+ training area nerfed.
Addons Installed to Stock-ish Realm
  • Action Mod: Adds more actions in the game
  • Spell Mod (v2.0): Upgrades the vast majority of user spells in the game to raise level cap / increase damage / alter effects
  • Small Quest Changes: Makes some quests less annoying to deal with
  • Lair Mod: Increases number of monsters and regen in many areas
  • Caster Sashes: Adds belts for casters
  • Fighter Eyewear: Adds face items for fighers
  • 5th Weapon Trader: Allows the quest weapon from the 5th alignment quest to be traded for a different one
  • Obsidian Fortress: Small new area ( http://www.mudinfo.net/viewtopic.php?f=47&t=1480 )
Re: Euphoria BBS
Players can now view stats at https://www.mudinfo.net/euphoria.php
Raybdbomb
Re: Euphoria BBS
Post by Raybdbomb »
syntax wrote: Sat Sep 28, 2024 3:08 pm Players can now view stats at https://www.mudinfo.net/euphoria.php
how did you do this?
Re: Euphoria BBS
I can't take credit for the concept (link, link), just expanded on the idea. My WG/MMUD are configured to run on the newer PervasiveSQL engine and a PHP script utilizes ODBC to connect to it and pull data. I have a scheduled task that runs every 5 minutes that snapshots data from Pervasive and throws it into a MySQL database. The site then displays said data.
As I do with all things MajorMUD, I wrote the code to be modular and easily function for anyone and will release it all once I think it's in a good spot.
Re: Euphoria BBS
FYI, my house lost power and because I'm at work, my UPS's died before I could hook up a generator. I do have a whole house generator coming sometime in the next few months.
edit: it's back up
