Megamud Keeps trying to Equip
dbcooper
Post by dbcooper »
When I specify which weapon I'm using in Megamud it tries to equip it before each attack. Is there anyway to stop this from happening>
Re: Megamud Keeps trying to Equip
Are you on a stock board and the weapon is two handed?
If so you are stuck cause they changed the wording of two-handed weapons when equipped. So mega doesn't see it eq'd and re-eq's it every time. You can not use auto-switch with two-handed, you have to put random garbage in those two fields to get mega not to try equip every time.
Mustang05241984
Post by Mustang05241984 »
Thank you for this info, just made a post asking this same question, should've looks before I posted!
