MudRev Information
Re: MudRev Information
is there anything anywhere about the new races and classes and maybe even some spells... i got a few guys looking for a lil more detailed info about them
Best bet is to have the sysop create an MME dat file and pass that along to players. Mudrev info is hard to find since so many version exist, and who knows which version they are running.
I thought I was on to something when I found an old mudrev site on the wayback machine. but the only page that provided anything useful i hadn't seen on here already was this:
Quickling Area
Recommended Min Level: 20; Max Level: 30
Located to the Northeast of the Torchlit Caves. The new Quickling area is filled with Quickling Mages as well as other variety of quicklings.
Mermex royal guards
Recommended Min Level: 20; Max Level: 40
Mermex soldiers and royal guards roam the tunnels beneath the mermex queen. This is a very good low-level cash spot.
Dragon Serpents
Recommended Min Level: 20; Max Level: 55
Dragon serpents roam the tunnels underneath the Ancient Ruins. There are two bosses in this area, level 45+ recommended. This area, like the Ruins, is restricted to level 55 and below.
Bloodbear tunnels
Recommended Min Level: 20; Max Level: 50
Bloodbears wander the tunnels beneath the bronzewood forest, with a difficult boss (level 100+). Decent exp from the area.
Kobold elites
Recommended Min Level: 10; Max Level: 20
Fanatical kobold mages and fighters roam the tunnels beneath the kobold king. This is a good low-level cash spot.
Fire ants
Fire ant soldiers roam the ant farm beneath the queen ant. There is a wandering boss in this area, the giant fire ant.
Quickling Area
Mermex royal guards
Dragon Serpents
Bloodbear tunnels
Kobold elites
Fire ants
Got a question, do you remember any good mid level(60-75) cash spots? Stuff is hella expensive
I was running crimson fort for pretty good cash but found a better exp spot, wondering if there's anything better for cash.
Area: New Rakshashas
Description: rakshasha sorcerors, rakshasha elite guard, rakshasha lord
Recommended Levels: 60+? mag 5 for lord
Who scripts here: roomer? any?
Get an angular key from rakshasha rajah or nazareen key shop and it's north of the oasis.
lord is in 16/4060 where the loop starts, and is a super easy 76 mil 2 hr regen boss in the loop. I get about 150mil here killing regen with a single roomer.
Adding on to this--apathy wrote: Sat May 21, 2016 12:47 pm To get there via the portal you need to visit it first and purchase a Southwind Dale Feather.
Turns out, it goes like this:I'll path it and we can add it to the MudRev paths
- Go to Mind Flayer Magus's room
- Go portal
- Use black skull key up (from black soul), then go up
- Exit the castle and use MME to walk S for awhile, and you're there.
#1) The black soul is in the room down from the level 100 trainer, which you need to be level 90 to get to.
#2) Once you use the black skull key up to the darken castle, you can then use the megamud mudrev path to "Southwind dale, Jewelry" to buy your southwind dale feather. Once you have that, you can use the portal to get to southwind in the future (5 runic to use portal).
