Scripting Programs
Re: Scripting Programs
Have you made up a set of mess and resp for this new poison? Might do that and check "poison" so mega knows it's a poison. It might also be the kang part, where mega might auto ignore poison cause he's a kang? Really just a stab in the dark.
I am just going to have to ignore the poison. No one can figure out if there is a @poison command, and the message/reply isn's working (I cant get the priest to cast cure with straight triggers I set up personally.
Like I said earlier. This would'nt be difficult if there was a simple easy IF/THEN set up. But since this program is so old, doubt that will happen
I just walked into the Pastors office found my curi spell. What I will do is a pre rest command where the priest will just cast curi before resting. That should cure evryone in the party
I give up.
I thought the curi spell cast a cure poison for the group. Not curing anything at all. Just blew threw 700 mana chain casting curi because it wont clear poison...
BearFather wrote: Thu Oct 18, 2018 9:58 am Edit:
C:\Users\<user>\AppData\Local\VirtualStore\Windows\MegaMud.INI
change AutoLoadIni=1 to AutoLoadIni=0
Check the Directory= a valid place
\\HKEY_CURRENT_USER\Software\GWiz\MegaMud\Directory make sure that matches up.
I am having the same problems. Numerous times I have followed these instructions, but I have not had luck.
I do not have - C:\Users\<user>\AppData\Local\VirtualStore\Windows\MegaMud.INI on my hard drive. Recommendations or suggestions?
Also, this problem began for me when I attempted to save as under a new folder for a second character. I was having troubles with the auto loop / roamer confusing settings between a mage and paladin while grouped.
I don't wan to give up on this game, but I question how feasible this is. I have spent a lot of time trying to correct this issue.
From: http://www.mudinfo.net/viewtopic.php?f=4&t=2059ohno wrote: Wed Mar 06, 2019 2:07 amI am having the same problems. Numerous times I have followed these instructions, but I have not had luck.
Have you checked in "C:\Users\YOURPROFILENAME\AppData\Local\VirtualStore\Program Files (x86)\Megamud" and/or the regular directory of "C:\Program Files (x86)\Megamud" ?
Thank you for the link.syntax wrote: Wed Mar 06, 2019 8:15 amFrom: http://www.mudinfo.net/viewtopic.php?f=4&t=2059ohno wrote: Wed Mar 06, 2019 2:07 amI am having the same problems. Numerous times I have followed these instructions, but I have not had luck.
I followed the instructions. Now I am receiving a new error code of - Cannot find file MEGARES.DLL
Mine is not showing it as installed . . . . Little help pls?Gridlocked wrote: Thu Oct 18, 2018 9:00 am
https://www.facebook.com/photo.php?fbid ... =3&theater
Link shows it is installed.. with no way to uninstall per your instructions (I just go right to the control panel and search)
Thank you for your time.ohno wrote: Wed Mar 06, 2019 2:40 pmMine is not showing it as installed . . . . Little help pls?Gridlocked wrote: Thu Oct 18, 2018 9:00 am
I just figured it out.
Thank you for your time.ohno wrote: Wed Mar 06, 2019 11:09 amThank you for the link.syntax wrote: Wed Mar 06, 2019 8:15 amFrom: http://www.mudinfo.net/viewtopic.php?f=4&t=2059ohno wrote: Wed Mar 06, 2019 2:07 amI am having the same problems. Numerous times I have followed these instructions, but I have not had luck.
