Scripting Programs
Re: Scripting Programs
make sure you have megamud ver 1.03u then get the winterhawk update if on an edited realm find out if it offers paths and loops for added or edited areas.
Gridlocked
Post by Gridlocked »
The latest version i need to install winter's pack..i was told not to install MM in the program file direct is that true?
Gridlocked wrote: Wed Oct 17, 2018 11:43 pm The latest version i need to install winter's pack..i was told not to install MM in the program file direct is that true?
http://www.mudinfo.net/viewtopic.php?f=4&t=2059
Gridlocked
Getting an error after removing the program.. cleaning the registry of any megamud then reinstalling it to a new directory C;\MegaMud
Getting the following error:
your ini file does not appear to be within the "Chars" sub-directory
have permissions set to full for users for directory ect
running in admin
Gridlocked
Ok cleaned it again.. installed in program files86..followed the instructions in the previous link. I still get the character ini file sub directory ...
Gridlocked wrote: Thu Oct 18, 2018 5:46 am Ok cleaned it again.. installed in program files86..followed the instructions in the previous link. I still get the character ini file sub directory ...
Uninstall it, delete the folder from program files, delete the folder from C:\Users\<YOURPROFILENAME>\AppData\Local\VirtualStore\Program Files (x86)\Megamud and start over.
Gridlocked
Still get same error..Could it be a regestry key ?
Gridlocked
I would think an install would rewrite all registry entries correctly
Gridlocked
By the way -- in windows 10 Control panel the program is not listed. it has no uninstaller.. so I have just been deleting the folder....
Gridlocked wrote: Thu Oct 18, 2018 8:31 am By the way -- in windows 10 Control panel the program is not listed. it has no uninstaller.. so I have just been deleting the folder....
that's probably your problem. it definitely has an uninstaller. when you go to "apps & features" in windows 10, click on "programs and features" under "related settings". This will bring up the old style program listing.
