MudRev Quest Information
Discussion relating specifically to the popular MudRev dats.
This is not my work, it was uploaded the the mud dev facebook group, and was credited to scott field.
The following write-up will concentrate on the "new" quests related to the MudRev build. This will contain a walk-through to each quest, including items needed, flags you will receive, and rewards that are given. This document will NOT include any quest that is already within a "stock" realm build. Those quests, and related information, can be found on http://www.mudinfo.net.
MudRev brought forth a bunch of new quests to ease the leveling process, and to remove some of the boredom of just scripting. All the new quests can be found in the game itself by typing "? quests". This list will show each available quest and the corresponding level requirements. Also, there will be a highlighted part to each quest as listed. If you type: "? <highlight>" you will be able to see the rewards for said quest.
There are two notable changes to prior quests in a stock realm in MudRev. The first is the Bishop/Golden Chalice quest. In a stock realm, this quest is achievable at level 15. However, in MudRev, the quest has been updated to a level 55 quest, and correspondingly, the level range of monsters in the Black Fortress have been updated to compensate. The details of this quest, though, remain the same as the stock realm version.
The second change is the addition of the Nahr Castle Quest. This quest is actually in a stock realm, but it is not known as a "quest" per say. In fact, this is known as the "Uber Super Big Jumbo Trainer." It was a trainer used to train from 65-75 (a stock realm's cap). However, the method to get to the Spacelord is the same between both MudRev and a stock realm. I will go through the basic changes between the two to update the steps for MudRev quest completion. I will not, however, do a write-up for the whole quest. If you need that information, go to http://www.mudinfo.net/maps/phantoms/maps_111n.htm, and look at the maps for Ancient Fortress. These maps combined with the MudRev MME can be used to figure your way through the quest. Plan to spend a few hours deciphering everything, but in the end it is not that bad. You just have to have basic understanding of MME flags and textblocks.
*EDIT* http://www.greatermud.com/forums/index.php?topic=2167.0 for a walkthrough of Nahr thanks to DeathCow, since everyone seems too lazy to do their own research.
-- Localized here: http://www.mudinfo.net/viewtopic.php?f=13&t=2055
Ok, on to the quests. After certain steps, there will sometimes be some numbers in parentheses. These numbers are quest flags that are received after that step is complete. This also means that when you do this particular step, you CANNOT be 10-spelled. This counts for just talking to a NPC or killing a NPC. If you are 10-spelled, you will not be able to get the quest flag, and you will not be able to continue the quest until you do the step without 10-spelling. If you don't know what 10-spell means, ask someone or just quit playing all-together.
Faerie Queen: Level 25+
  1. Go to Northern Forest - Faerie Ring
  2. Greet Faerie Queen
  3. Ask Faerie Queen services (202 1)
    a) She will give you a tiny jeweled key
  4. Go to Northern Forest - Quickling Lord
  5. Kill Quickling Lord (202 2)
    a) You will receive bracelet of haste
    b) You will receive 10 million exp
Dark-elf Queen: Level 35+
  1. Go to Dark-elf City - Dark-elf Queen. There are some steps to get to her, figure it out.
  2. Kill Dark-elf Queen
  3. While in her room, after everything is dead, sit throne (15 1)
    a) You will receive 15 million exp
    b) You will receive +10 hps
Fire Twins: Level 45+
  1. Go to Volcano - Fire Twins
  2. Kill Vashti and Vasili
  3. While in their room, after everything is dead, destroy altar (152 1)
    a) You will receive 80 million exp
    b) You will receive +100 Illu
    c) You will receive the ability of Tracking
    d) You will receive firestone
NOTE: This quest is the start of a chain of quests in MudRev. The firestone is an item that you must keep with you for future quests. Also, the (152 1) flag is needed before you can complete the next quest in this series.
Spectral Knight: Level 60+
  1. Go to Graveyard - Spectral Knight
  2. Kill Spectral Knight (201 1)
  3. Go to Sewers - Forgotten Dragon Slayer
  4. Ask Forgotten Dragon Slayer demise (201 2)
  5. Go to Sewers - Forgotten Dragon
  6. Kill Forgotten Dragon
    a) Loot severed prismatic dragon claw
  7. Go to Sewers - Forgotten Dragon Slayer
  8. Ask Forgotten Dragon Slayer token (201 3)
    a) You will receive 150 million exp
    b) You will receive dragonscale belt
Darken Beast Lord: Level 65+ (Quest #2 of 152 line mentioned earlier)
  1. Go to Blackwood Forest - Darken Beast Lord
  2. Kill Darken Beast Lord (152 2)
    a) You will receive 225 million exp
    c) You will receive firestone pendant
Nahr's Castle: Level 70+ (Quest #3 of 152 line)
As mentioned before, I am not going to write a walk-through to this quest. The methods to getting to the Spacelord are the same as a "stock" realm. Noted changes:
  1. After you kill the final version of Nahr you get (152 3)
  2. Once at Spacelord, ask Spacelord nahr (152 4)
    a) You will receive 1 billion exp
    b) You will receive +3 HitMagic
    c) You will receive +10 MR
Poseidon's Crown: Level 80+
  1. Go to Atlantis - Poseidon
  2. Ask Poseidon trouble (181 1)
  3. Go to Atlantis - Lord of the Sea. This will require you to gather a few keys from bosses located in the Ruined Palace. If your mega won't auto-gather them, do it by hand. Maps are in MME.
  4. Kill Lord of the Sea (181 2)
    a) Loot Poseidon's Crown
  5. Go to Atlantis - Poseidon
  6. Ask Poseidon return (181 3)
    a) You will receive 750 million exp
    b) You will receive +10 acc
    c) You will receive +20 SC
Dhelvanen's Scrying: Level 90+
  1. This quest requires you to gather five items from various bosses in the realm. The order in which you gather them does not matter. Once you have them all, go on to step 2. There are not gotos for most of these bosses, so I will give general directions. The items and bosses you need are as follows: (Note: some of these items have a very low drop rate. Have fun!)
    a) Go to Nazareen - Dark Castle. In the basement, on the west side, is the boss Vampire Dragonbat. Kill it and loot dragonbat fang.
    b) Outside the Western Gate of Nazareen are the pink bunnies. When the path splits, head northeast and along that path is the boss
    Giant Pink Bunny. Kill it and loot pink rabbit's foot.
    c) In the Black Fortress, go to Alchemist. There is an exit D from his room. In that area is a roaming boss Dark Giant Warlock. Kill it and loot dark giant heart.
    d) Go to Black Mountains, located in Dragon's Teeth Hills. In the far NE corner there is a boss Displacer BeastLord. Kill it and loot
    displacer beast hide.
    e) Go to Dark Forest - Massive Blue Wyvern. Kill it and loot blue wyvern scale.
  2. Go to Black House - Dhelvanen
  3. Ask Dhelvanen require (200 1)
    b) You will receive onyx bracelet
Gnaj's Prisoner: Level 100+ (Quest #4 of 152 line)
  1. Go to Spacelord (will now port you directly there from first room of Ancient Fortress)
  2. Ask Spacelord zanthus (152 5)
  3. The next part requires you to get to the Timelord. Unlike a stock realm, he is not located directly one room U from the Fallen Angel. Instead, you go U from Fallen Angel and have to go through a long series of rooms with some pretty tough monsters and a boss. You need to kill the Dark Champion for a key. The key is used in the last room of this area to access the Timelord. Go to Timelord.
  4. Ask Timelord helvectus (152 6)
  5. Go to Gnaj the Creator. He is in the same place as he is on a stock realm. However, you cannot use the NPP portal to access his room until AFTER you do this quest. Stupid I know.. blame the creators of MudRev. This means that you have to go the super long way through the Dwarven Mines. Get a map and have fun. (Note: The gnaj monsters hit extremely hard now, be warned)
  6. Kill Gnaj the Creator (152 7)
    a) Loot 2 glowing yellow eyeball
  7. Go to Halfling Prisoner. This is two rooms away.
  8. Ask Halfling Prisoner gnaj
  9. Ask Halfling Prisoner secret
  10. Ask Halfing Prisoner helvectus (152
    a) He will take the eyeballs and become attackable
  11. Kill Halfling Prisoner. He will summon Chaos Demonling.
  12. Kill Chaos Demonling (152 9)
    a) You will receive 1.5 billion exp
    b) You will receive eyes of the Creator
Ok, that completes all the new side quests that MudRev has to offer. The following quests are going to document the continuation of the alignment quests from stock realms. This includes the evil/neutral/good versions of the 6th and 7th alignment quests. And yes, you have to have done the previous 5 alignment quests before you can do these. And yes, you HAVE to kill Zanthus the Lich in the 5th quest for all alignments in MudRev.
6th Alignment Quests: Level 75+
EVIL
  1. Go to Nazareen - Demonic Enchantress.
  2. Ask Demonic Enchantress alliance (128 32)
  3. Go to Elemental Forest - Lichen Astromancer
  4. Ask Lichen Astromancer service (128 33)
    a) Receive lichen tome
  5. Go to Nazareen - King of Nazareen
  6. Ask King of Nazareen charm (128 34)
    a) Receive elemental charm
  7. Go to Elemental Forest - Archdruid
  8. Kill Archdruid. (128 35)
    a) Receive Wicca Pendant
  9. Go to Elemental Forest - Lichen Astromancer
  10. Ask Lichen Astromancer return (128 36)
  11. Go to Nazareen - Demonic Enchantress
  12. Ask Demonic Enchantress return (128 37)
  13. Go to Rhuduar - Balthazar
  14. Ask Balthazar deed (128 41)
    b) You will receive obsidian chest (make sure you have 2k inv)
NEUTRAL:
  1. Go to Nazareen - Zedwic
  2. Ask Zedwic aid (127 32)
  3. Go to Elemental Forest - Lord of the Woods
  4. Ask Lord of the Woods require (127 33)
  5. Go to Nazareen - Ice Wizard
  6. Kill Ice Wizard (127 34)
    a) Receive loot elemental scroll
  7. Go to Elemental Forest - Lord of the Woods
  8. Ask Lord of the Woods protect (127 35)
    a) Receive scroll of elemental rage
  9. Go to Khazarad - Kai Lord
  10. Kill Kai Lord. (127 36)
    a) Receive Storm Pendant
  11. Go to Elemental Forest - Lord of the Woods
  12. Ask Lord of the Woods return (127 37)
  13. Go to Nazareen - Zedwic
  14. Ask Zedwic return (127 38)
  15. Go to Darkwood Forest - The Grey Lord
  16. Ask The Grey Lord journey (127 41)
    b) You will receive titanium chest (make sure you have 2k inv)
GOOD:
  1. Go to Nazareen - King of Nazareen
  2. Ask King of Nazareen chancellor (126 32)
  3. Go to Elemental Forest - Archdruid
  4. Ask Archdruid sent (126 33)
  5. Go to Nazareen - Occult Martyr
  6. Kill Occult Martyr (126 34)
    a) Receive unholy scroll
  8. Ask Archdruid empower (126 35)
    a) Receive scroll of druidic fury
  9. Ask Archdruid prayer (126 36)
  10. Go to Elemental Forest - Lichen Astromancer
  11. Kill Lichen Astromancer (126 37)
  12. In the same room, after cleared, purify altar (126 28)
  13. Go to Elemental Forest - Archdruid
  14. Ask Archdruid return (126 39)
  15. Go to Nazareen - King of Nazareen
  16. Ask King of Nazareen return (126 40)
  17. Go to Chancellor Annora
  18. Ask Chancellor Annora journey (126 41)
    b) You will receive platinum chest (make sure you have 2k inv)
7th Alignment Quests: Level 100+
EVIL: (Note: This quest seems bugged and unfinished. Just a heads up)
(*EDIT* Quest has been fixed)
  2. Ask Demonic Enchantress task (128 42)
  3. The next step is to collect items from two dragons, doesn't matter which order.
  4. Go to Sewers - Diamond Dragon
  5. Kill Diamond Dragon (128 43)
    a) Loot diamond dragon scale
  6. Go to Sewers - Demonic Dragon
  7. Kill Demonic Dragon (128 44)
    a) Loot severed demonic dragon claw
  8. Go to Nazareen - Darken Castle. Locate Necrolyte Lord
  9. Ask Necrolyte Lord ritual
  10. Kill Necrolyte Lord (128 45) (128 46)
  11. Go to Rhuduar - Balthazar
  12. Ask Balthazar ritual (128 47)
    a) You will receive 3 billion exp
    b) You will receive +100 Hps
NEUTRAL: (Both the Neutral/Good 7th work as intended)
  1. Follow steps 3-10 of evil 7th (127 45)
  2. Go to The Grey Lord
  3. Ask The Grey Lord ritual (127 47)
GOOD:
  2. Ask King of Nazareen task (126 42)
  3. Follow steps 3-10 of evil 7th (126 46)
  4. Go to Chancellor Annora
  5. Ask Chancellor Annora ritual (126 47)
Re: MudRev Quest Information
Another Writeup (not written by me):
MudRev Quest Walkthroughs
Ice Sorceress: Level 15+
  1. Sit throne in ice sorceress room = 125(2)
    a) You will receive +1 AC and 1.5 million exp
High Druid: Level 15+
  1. Touch gem in high druid room = 129(2)
    a) You will receive +1 S.C. and 1.5 million exp
Phoenix Feather Quest: Level 15+
  1. Locate the Old Man in the Asylum. Ask old man phoenix
  2. Exit the game, come back into the game. Go South, then West. You'll be outside of the Asylum now.
  3. Go to the Thieve's Guild. Purchase a Skeleton Key.
  4. Kill the Dread Mystic. You will get a Yellow Note.
  5. Kill the Smuggler Boss. You will get a Smuged Paper.
  6. Go to Orfeo and ask him about Morukai.
  7. Greet Morukai and ask him about Orfeo.
  8. Ask him about the stuff that is highlighted.
  9. Find the four components.
    a. Eggs: Located below the Tilled Fields in the Gnome Village.
    b. Quartz: Located in the Bandit Keep near Aldreth's Tree. At the door, search North for a secret passage. Go
    Tree and
    you'll be inside the keep.
    c. Roots: Located past the Jagged Hills in the Dragonteeth Hills. The Jagged Hills are on the northern side
    of the Dragonteeth
    Hills between Silvermere and Passage to the Silver River.
    d. Acid Glands: Located below the Mad Wizard. Kill the White Jelly for it.
  10. Go to the Gnome Alchemist and ask him about Potion. Take 1 plat with you for purchase.
  11. Go to the Gnome Inventor and ask him about FORKS.
  12. Go back to Morukai and ask him about components. Ask him about Return.
  13. Locate the Haunting Spirit.
  14. Type DESTROY BARRIER to use the Magical Rod of Quartz to open up the passage.
  15. Find the Necromancer beyond the Shimmering Barrier and kill him for the Phoenix Egg.
  16. Return to Morukai and ask him about INFORMATION.
  17. Go to the Lava Fields and locate the door to the North. Use the Basalt Key to open the door. Once inside, type HURL EGG.
    a) You will receive 25 million experience
    b) You will receive phoenix feather
Sunstone Wristband Level 20+
  1. Ask nekojin elder traders
  2. Kill some saracens for a head (ones in desert don't drop them, only ones in the saracen hideout) and go to the small pyramid
  3. Ask ser head
  4. Ask trader favor
  5. Ask meia box
  6. Ask trader return
  7. Ask seeress accept
  8. Go to the library in the golden palace, read blue book, peruse blue book, read red book, peruse red book. There's an intelligence/wisdom check on the red, so keep trying if you fail.
  9. Ask seeress return
  10. Ask withered old man ale (have some dwarven ale, bought in khazarad)
  11. Obtain some red iron weapons. Doesn't matter if you get them the usual way (buy pickaxe, go to mummified miner, examine miner, go to and kill the hideous abomination, mine ore, ask martok red iron weapon with about 20 plat on you) or get one from somebody else, or even just let others do the attacking just be in the room.
  12. Go through the pyramid. For the least amount of pain, ten spell before going into the first level so you don't have a timer. Map out a path through the second level, and do it by hand. RUN. Do not stop unless someone gets held by an undead priest. On the third level, just a use a map and go by hand. It's not hard really. On the fourth, let MegaDUM do it but fight on the way because if you go back you'll get dropped from the pyramid.
  13. Kill the pharoah. Rest, spell up, go portal, kill dao lord.
  14. Ask orfeo dao
    a) You will receive 50 million experience and a sunstone wristband
Quickling Lord (Faerie Queen) - Level 25+
  1. Go to Faerie Ring
  3. Ask Faerie Queen services (173 1)
  4. Go to Quickling Lord
  5. Kill Quickling Lord (173 2)
Apparatus: Level 25+
  1. Destroy Apparatus
    a) You gain +1 Dodge and 10 million exp
  1. Go to Dark-elf Queen. There are some steps to get to her, figure it out.
Adult Red Dragon: Level 35+
  1. Kill adult red dragon
  2. Touch ruby
    a) Receive +1 Crits, +2 S.C., 50 million experience
  1. Go to Fire Twins
Golden Chalice
  1. Kill COB/Greater Hellion and ask bishop reward
    a) Receive white satin gloves, white satin tabard, and 150 million exp
  1. Go to Spectral Knight
  2. Kill Spectral Knight (55 1)
  3. Go to Forgotten Dragon Slayer
  4. Ask Forgotten Dragon Slayer demise (55 2)
  5. Go to Forgotten Dragon
  7. Go to Forgotten Dragon Slayer
  8. Ask Forgotten Dragon Slayer token (55 3)
Darken Beast Lord: Level 65+ (Part #2 of Quest with 152 flag)
  1. Go to Darken Beast Lord
Nahr's Castle: Level 70+ (Part #3 of Quest with 152 flag)
As mentioned before, I am not going to write a walk-through to this quest. The methods to getting to the Spacelord are the same as a “stock” realm. Noted changes:
Episode 1, The Begining.
Your adventure begins on map 12 room 2368 . From her you head north and then east. The eastern exit is level 50 restricted. You head east one more time and fall into a pit and fight an illusion boss. This illusion will be either: ancient sand dragon<1034>, fallen angel<1035>, aged earth dragon<1036>, or Dao Lord<1037>. When the monster is dead you will be teleported back into the room you fell from. Until you reach the hedge maze be on the look out for the angelic hunter<1012> he can regen in anyroom after the pit until you reach the hedge maze<7 rooms away>as well as ancient sand dragon<1034>, fallen angel<1035>, aged earth dragon<1036>or Dao Lord<1037>. From the room above the pit head south twice. Here you fight your first Nahr illusion <1004>. From here you go e, ne, ne, n. By know you should have fought and killed the angelic hunter<1012> and taken the ancient key<1899> that he drops. If you have not yet walk around until you find him and return to the locked gate your the west. Open the gate and head west when you are ready. Its worth noting that many so the items that you would collect later in the fortress will be removed from your inventory in this and the following areas by room spells that are active in most rooms of the fortress. Also once you fight one of the illusion creatures, you will not have to fight that same creature for another hour so it may be worth your time to fall into the pit several times and kill all of the illusions before continuing.
Episode 2, The Hedge Maze.
The Hedge Maze begins on map 17 room 2868. And is riddled with high damage traps. Begin by heading north, north, north, southeast, southeast. Directly to your west is a monster named beautiful woman<1027>, and like the women from rakashashas she will transform into a more powerful monster when killed, Lorzina<1032>. One killed collect the tree branch and return to the start position. Now head south south south ne<400 damage trap> To your northeast is a handsome man that does not transform. Head back to start position swsw n and the north north. Now go sw west west west north north east east north east In this room there will be a withered tree that will take both the tree branches from you. When both branches are taken Azrandimon<1030> will be summoned into the room. Kill him, grab the stone rook key<1902>, and head to the closed gate to the south you past sw of the start position. All exits are trapped on the way. This area spawns the illusion monsters, great green dragon<1038>, giant roc<1039, Darken Beast Lord<1040> and Lord of the Hunt<1041> so be careful when walking through the area, as before you'll only have to fight each illusion once. Using the stone rook key<1902> open the gate. South is the Majestic Dragon<1013> once he is killed and a few seconds has passed you will be teleported to Map 17 Room 2980 Ancient Fortress with the NPC demon imp<1033>
Episode 3, Heaven and Hell.
Begin by heading west and entering the portal. You must be at least level 60 to continue any further. In this room Floating Island you'll use the command "say king of spades" Afterwords there will be a flash of light. Go west west west and use the command"say Nightfall" afterwords there will be a flash of light. Go south south south and use the Command "say h" afterwords there will be a flash of light. Now go n, n, n, n, n, n, w, s, s, w, int he room to you west will be the Golden Phoenix. Prepare a "get rod^M" macro and head west. As soon as the phoenix dies hit your macro and get the Golden Rod<1910>. You will be teleported back to the demon imp<1033> in room 2980 map 17. Head east go portal and be teleported to Burning Valley. As a note for this area everytime you push a boulder you wil first have to pass a strength check at -60, if you fail you will have the spell seared by the flames<1324> cast on you are receive damage. Also this area regens monsters in a similar fashion to the previous areas except that spiked juggernauts<1048> and fanged demons<1051> have no limit to how often they can rgen, Devil Fiend<1049> and Demoness<1050> also regen in this area they are limited to one per hour. Go s e, move boulder, south, e, s, move boulder, e, north, move boulder, north, move boulder, north, move boulder, north, w, s, sw. You'll be at Map 17 room 2976 Burning Valley with NPC demon imp<1052>. He requires 20 black spikes<1912> which have a 5 chances of 10% of dropping from spiked juggernauts<1048>. Simiply remain still in the room with the Demon Imp until you have collected 20. Speak to the imp and receive a slimey spiked key<1901> in return for 20 black spikes<1912>. Prepare a "get ball^M" macro and use the slimey spiked key on the door to your west. Go wet and kill Demon Lord<1015> quickly grab the black spiked ball<1911> and you will be teleported back to Map 17 Room 2980 Ancient Fortress with the NPC demon imp<1033>. Speak with the demon imp<1033> and he will take the Golden Rod<1910> and the black spiked ball<1911>.
You will be teleported to Dark Cavern and have to kill Great Hydra<1016> and 2 massive hydra heads<1029>.
Go Portal and you will be teleported to Map 17 Room 2982.
Episode 4, ABC and Some Stupid Shit.
You Must be at least level 65 to continue. If you are level 66 you can skip Episode 4.
Episode 4, A. If you are a priest, a mage, a druid, or a warlock head southwest otherwise skip section A. Go e s s w s e s, kill the inquisitor<1019> collect the sapphire key<1943>. Go n, w, w, s, w, n, n kill the inquisitor<1020> and collect the iron key<1945>w, kill the inquisitor<1024> and collect the stone key<1944>. Go n, n, kill the inquisitor<1021> and collect the ruby key<1941>. Go n, e, e, s kill the inquisitor<1022> and collect the amber key<1942>. Use the stone key<1944> on the east door. Enter the room and quickly type summon shard. Your primary casting stat will be tested at -40, or both wisdom and intellegence at -20 if your a druid. After a two second delay you will either have the shard or you will have failed the test. This room does stone based damage you can rest outside the room if you take too much damage before getting the shard. Once you have the quartz shard<1950> go w n w w s use the sapphire key<1943> east go east and repeat the summon shard statstics test again. Once you have the sapphire shard<1949> go w s s and use the amber key<1942> south. Go south and repeat the summon shard statistics check. Once you have the amber shard<1948> go n, e, s, e, n, e, e, s, use the ruby key<1941> on the western door. Go west and repeat the summon shard statistics test. Once you have the crimson shard<1947> go e n w w s w n n and use the iron key<1945> on the eastern door. Speak with the prisoner he will take the shards give you multicoloured staff<1916> and teleport you to Map 17 Room 3231 Blackstone Cavern. Here you must collect nexus ore<1955>. Go west and type gather ore. If you pass a test on your primary spellcasting stats you get the nexus ore<1955>. <-40 wis for priests, -60 int for mages and warlocks, -40 int and -40 wisdom for druids>. Continue attempting to gather ore from one of the four room surrounding the room you teleported to Map 17, Room 3231. Once you gain 10 peices the ore go back to Map 17, Room 3231. Equip the multicoloured staff<1916> and use the staff. The ore will be taken and a Nexus Portal will appear in the room. Enter the Portal and You will be teleported to Map 17, room 3236 and Nahr<1009> will be summoned. Kill Nahr and enter the Nexus Portal again. Continue with Episode 5.
Episode 4, B. If you are a witchunter, warrior, paladin, cleric, mystic or a ranger head south south. Bash open the door to your south and go through the door, your now on Map 17, Room 3057. Go south south east and kill white guardsman<994>.
Collect the dropped item white pawn<1933>. Go north will be taken from your inventory> and then north once more. Go east kill the Black Knight<995> and take the item black knight<1934>. Go east will be taken from your inventory>. Go south south. At this point you will be on Map 17, Room 3073. Kill the white bishop<996> and take the item white bishop<1935>. Go south will be taken from your inventory>. Go south west, kill the black marble golem<997> and take the item black rook<1939>. Go north will be taken from your inventory>. Go west west, kill the white queen<998> and take the item white queen<1936>. Go west will be taken from your inventory. Go north north, kill the black king<999> and take the item black king<1937>. Go north will be taken from your inventory>. You will now be on map 17 in room 3189. Go south south and kill the white guardsmen<1065>. Go south once more, kill white king<1070> and and collect crown key<1940>. Go north north north, and use the crown key<1940> on the door to the north. Go north west and you should now be on map 17 room 3196. Go north north and kill the black guardsmen<1071>. Go north and kill the black king<1076> and enter the nexus portal. AFter going through the portal you will now be on Map 17 room 3028. This small 9 room area is shaped like an "S" on its side. Nahr<1006> will rgen in either Map 17 Room 3029; Map 17, Room 3033;Map 17, Room 3035. Find him, kill him, and take the helmey key<1930>. That he drops open the northern door that appears in the center middle of this area and go north. Continue with Episode 5.
Episode 4, C. If you are a thief, ninja, missionary, bard, or a gypsy head southeast southeast, pick the lock to the southeast and go southeast once more. You'll be on map 17 Room 3036 with the neutral NPC cloaked figure<1056>. Use the command steal from cloaked figure until you pass the thievery skill test and get the pearl<1923>. Now kill cloaked figure<1056>. When he dies he will summon cloaked figure<1061> kill cloaked figure<1061> and collect the moonstone<1922>. Pick the door to the east and go east. The neutral NPC cloaked figure<1054> will be in the room. Use the command steal from cloaked figure until you pass the thievery skill test and get the diamond<1921>. Go west, north and use the command put diamond in hole. Go south east north and use the command put pearl in hole. Go south east and your now in a room with the neutral NPC claoked figure<1057>. Use the command steal from cloaked figure until you pass the thievery skill test and get the marble<1924>. Go north and use the command put moonstone in hole. Go east south and use the command put marble in hole. Go north north. Your now on map 17, room 3044. If you are a missionary or just unable to pass the thievery test for some other reason. You can kill each of the cloaked figures was outlined> and after killing the agressive versions of the figures will be able to get the items. If you can pass the thievery tests you don't need to kill cloaked figure<1056> and can instead use the steal from cloaked figure command on the last cloaked figure<1055>. Either way once you finish putting rocks in their holes go north through the newly discovered exit in Map 17 room 3042. Now disarm the trap to your west. Now go west, disarm trap north, north, disarm trap north, west, disarm trap south, south, disarm trap southwest, south west. You are now in Glowing Chamber. Use the command grab crystal. You'll take 260-390 damage from the spell greatsword<1334> and be given crystal gem<1927>. Disarm the trap to the north east and go northeast, disarm trap north, east, disarm trap east, east, disarm trap south, south. You are now in Glowing Chamber. Use the command grab crystal. You'll take 260-390 damage from the spell greatsword<1334> and be given crystal gem<1928>. Now disarm trap north, north, disarm trap north, west. Your now in Dim lit Room with the neutral NPC old thief<1063>. Speak with the old thief<1063> he will take both your crystal gems and teleport you to Dank Alleyway and take the skull key<1929>. Use skull key<1929> on the door to your south and go south.Continue with Episode 5.
Episode 5, Screw the Spheres then Screw Nahr.
once you are in the first room in grand hallway go n, s, n, n, s, s, s, n, n. In the room north is Nahr<1010>, red sphere<1080>, blue sphere<1081>, green sphere<1082> and yellow sphere<1083>. Kill all the monsters and type sit throne. All spell cast on you will be dispelled, you will teleport to Deep Black Pit<12/2378> and Nahr<1011> will be summoned. If you do not want to fight Nahr <1010> use this path instead Go north, north, South, North, north, south, south, south, south , north north and sit throne. All spells cst on you will be dispelled, you will take 245-490 damage from the spell Blood Bath<1352> be teleported to Map 12, Room 2378 and Nahr<1011> will be summoned. Kill Nahr<1011> and Nahr<1084> will be summoned. Once Nahr<1084> has been killed you will be teleported to Playform Of Stars with the Neutral NPC Spacelord<539>
  1. Go to Poseidon
  2. Ask Poseidon trouble (154 1)
  3. Go to Lord of the Sea. This will require you to gather a few keys from bosses located in the Ruined Palace. If your mega won't auto-gather them, do it by hand. Maps are in MME.
  4. Kill Lord of the Sea (154 2)
  5. Go to Poseidon
  6. Ask Poseidon return (154 3)
    a) Go to Dark Castle. In the basement, on the west side, is the boss Vampire Dragonbat. Kill it and loot dragonbat fang.
    Giant Pink Bunny. Kill it and loot pink rabbit's foot. c) In the Black Fortress, go to Alchemist. There is an exit D from his room. In that area is a roaming boss Dark Giant Warlock. Kill it and loot dark giant heart.
    d) Go to Black Mountains, located in Dragon's Teeth Hills. In the far NE corner there is a boss Displacer BeastLord. Kill it and loot displacer beast hide.
    e) Go to Massive Blue Wyvern. Kill it and loot blue wyvern scale.
  2. Go to Dhelvanen
  3. Ask Dhelvanen require (156 1)
Gnaj's Prisoner: Level 100+ (Part #4 of 152 line of quest flags)
  3. The next part requires you to get to the Timelord. Unlike a stock realm, he is not located directly one room U from the Fallen Angel. Instead, you go U from Fallen Angel and nw,e,e,s,s,w,w,n,u,s,s,e,e,n,n,w,s,u,se,w,w,n,n,e,e,s,w, use runed adamantite key d,d. You need to kill the Dark Champion for a key. The key is used in the last room of this area to access the Timelord. Go to Timelord.
  10. Ask Halfing Prisoner helvectus (152 8)
EVIL
  1. Go to Demonic Enchantress.
  3. Go to Lichen Astromancer
  5. Go to King of Nazareen
  7. Go to Archdruid
  9. Go to Lichen Astromancer
  11. Go to Demonic Enchantress
  13. Go to Balthazar
NEUTRAL:
  1. Go to Zedwic
  3. Go to Lord of the Woods
  5. Go to Ice Wizard
  7. Go to Lord of the Woods
  9. Go to Kai Lord
  11. Go to Lord of the Woods
  13. Go to Zedwic
  15. Go to The Grey Lord
GOOD:
  1. Go to King of Nazareen
  3. Go to Archdruid
  5. Go to Occult Martyr
  7. Go to Archdruid
  10. Go to Lichen Astromancer
  12. In the same room, after cleared, purify altar (126 38)
  13. Go to Archdruid
  15. Go to King of Nazareen
EVIL:
  4. Go to Diamond Dragon
  6. Go to Demonic Dragon
  8. Go to Darken Castle. Locate Necrolyte Lord
  10. Kill Necrolyte Lord (128 46)
  11. Go to Balthazar
GOOD:
Don't forget the mini-quests like Smash, Meditate, Super Stealth, Lissom Overlord stealth/BS bonus quest, and the witchie quests!
This concludes the quest guide for all the new major quests available in MudRev. There are some small hidden side-quests which I did not mention. If you have any questions or concerns, or would like to type up or improve this document, please contact BaDbOy.
COMING SOON (hopefully): Kon'fehr Castle Quest (220+)
