c:\WGSERV.exe-Access Violation Attempt to read from :0
its the only place i get this error so far gonna run around and see if i get it other places but crashes worldgroup and reboots the bbs any info would be hugely apreciated
This is simply stating that you are logged in from the main console. You have a 256-user license, and the main console does not account for one of these lines, so you are using line "0" of your 256 lines available.badshark wrote:hopefully an easy fix i do find it wierd that it says user 0 of 256 so maybe i just dont have something set up right
This tells you to see the "Routines" section below for the exact reason for the crash. So, when you look at this section:badshark wrote: WORLDGROUP EXCEPTION @ 0043DB50 (see "Routines" section below)
Recorded 2/23/2015 13:42:42
Access Violation. Attempt to read from: 0
This tells us two subroutines {0043DB20 and 0043DB50} are trying to read from the disk at the same time, while subroutines {0043DB50 and 0043DB64} are trying to write to the disk at the same time, so you're getting an access violation error. This is normally caused by editing one of the WCC*.dat files and creating a situation where two rooms/monsters/etc has the same ID # assigned to it. If you've never edited your files, then it would most likely be a faulty installation. The steps detailed above by cjt will provide you a fresh re-install of the databases, and will fix the problem....unless you've edited the dat files. In which case, you will have to figure out where you went wrong, or use un-edited files to overwrite your changes. If you accomplish a fresh install using "clean" files, and the problem persists, let us know.badshark wrote: Routines:
0043DB20 _sameas < 0043DB50 < 0043DB64 _samein
Thanks, Joker. I learned a lot from your post as well.Joker wrote: This tells us two subroutines {0043DB20 and 0043DB50} are trying to read from the disk at the same time, while subroutines {0043DB50 and 0043DB64} are trying to write to the disk at the same time, so you're getting an access violation error. This is normally caused by editing one of the WCC*.dat files and creating a situation where two rooms/monsters/etc has the same ID # assigned to it. If you've never edited your files, then it would most likely be a faulty installation. The steps detailed above by cjt will provide you a fresh re-install of the databases, and will fix the problem....unless you've edited the dat files. In which case, you will have to figure out where you went wrong, or use un-edited files to overwrite your changes. If you accomplish a fresh install using "clean" files, and the problem persists, let us know.
