Hydra
Corvette
Hydra
Post by Corvette »
So my warrior finally has exp to go to level 51.
How difficult would the hydra be to kill?
Or should I try training elsewhere like the Timelord? Is there a level limit to get to the fallen angel?
Jaylor
Re: Hydra
Post by Jaylor »
Hydra would be very difficult for solo warrior (unless you have an insanely high ac/dr). Your best bet is to level up at the timelord (you can go to lvl 54 there I believe). Get yourself a roomer friend that will make life at the hydra much easier.
Corvette
Re: Hydra
Post by Corvette »
Jaylor wrote:Hydra would be very difficult for solo warrior (unless you have an insanely high ac/dr). Your best bet is to level up at the timelord (you can go to lvl 54 there I believe). Get yourself a roomer friend that will make life at the hydra much easier.
Thanks, anything I should watch out for in the negative power planes?
