sys map and sys goto
msdss
Post by msdss »
Two quick questions:
sys goto -- users that I grant wccgameop can goto everywhere except support.
is there a way to configure wccgameops to be able to go to this room as well?
sys map -- how can i grant a user access to sys map, but nothing else. i've found a setting in the wccmmud.ini that allows me to add a key, but that key only works if they also have wccgameop or wccsysop as well.
EpicMUD
Re: sys map and sys goto
Post by EpicMUD »
In 'Security and Accounting' you need to change the 'GAMEOPKEY: Key required to issue GAMEOP commands' to normal. Then with the wccmmud.ini you can define which class gets which command. So you can put map as normal and goto with whatever your gameop account name is.
msdss
Post by msdss »
Kick ass.
That did the trick.
The only thing left to figure out is this stupid ass top ten thing, and what the hell the 'bard cloak crash' is. lol
cjt
Post by cjt »
ahh...you must have been the one that emailed me about the bard quest cloak. Sorry, just had a lot going on. I'll respond to the email.
