Issue installing MMUD 1.11p with windows 7 64 bit
Drizzt
Post by Drizzt »
The version of this file is not compatible with the version of windows your runnin. Check your computers system information to see whether you need an x86(32bit) or x64(64bit) version of the program
Thats the error i get when i try to install mmud and i have installed it before and i tried using every compatibility mode there is...please help
Re: Issue installing MMUD 1.11p with windows 7 64 bit
well if ya know how to setup a vm you could setup a vm with xp then install wg and mud on it then copy from vm to win7
EpicMUD
Post by EpicMUD »
You can also just decompress the WCCMMUD.z file in a dos window right to your Worldgroup folder.
