WG port number setting
Prime
Post by Prime »
Where do I go to set the port number for WG. It seems that I have seen it before but just not able to locate the setting. I am running version 3.30. I have 2 pc's running an instance of WG but I need to have one on a different port number than the default port 23. I have tried googling for the answer and looked over all the documentation I could find and nothing has helped. Any help is appreciated.
cjt
Re: WG port number setting
Post by cjt »
Could it potentially be done with port forwarding?
Set your router to listen for a different port, like 2023, and a rule that would then forward all communication via 2023 to a specific LAN IP and port 23, which would be your second box running WG.
I'm not a networking guy, but assume this should be possible to configure.
