Problem with sys powers
tetsuo
Post by tetsuo »
On any account including the master sysop account anytime i try to use a sys command i just get command not recognized. What am I doing wrong here?
cjt
Re: Problem with sys powers
Post by cjt »
If you want to provide your users Sys Gotos and Sys map, WCCMMUD.ini should look like this:
EXP_IN_TOPGANG=1
MAXIMUM_BANK_BALANCE=0
BLANK_LASTNAME_ALLOWED=1
SYS_LIGHTNING_KEY=SYSOP
SYS_STATUS_KEY=SYSOP
SYS_ADDLIFE_KEY=SYSOP
SYS_RETRAIN_KEY=SYSOP
SYS_ALIGNMENT_KEY=SYSOP
SYS_EDITEVIL_KEY=SYSOP
SYS_SPEAK_KEY=SYSOP
SYS_LISTUSER_KEY=SYSOP
SYS_LISTLIMIT_KEY=SYSOP
SYS_USERINFO_KEY=SYSOP
SYS_JAIL_KEY=SYSOP
SYS_CHANGE_KEY=SYSOP
SYS_BUFFERS_KEY=SYSOP
SYS_CLEARSUICIDE_KEY=SYSOP
SYS_REPORT_KEY=SYSOP
SYS_TOPTEN_KEY=SYSOP
SYS_DISBAND_KEY=SYSOP
SYS_RELOAD_KEY=SYSOP
SYS_VERIFY_KEY=SYSOP
SYS_GOTO_KEY=NORMAL
SYS_MAP_KEY=NORMAL
Sysop gets the SYSOP KEY, everyone else gets the NORMAL key.
jtolar
Post by jtolar »
for ppl trying to figure this out You have to change the settings in the Security & Accounting options. Under WCCMMUD change your GAMOPKEY to NORMAL, then save and exit. then in the WGSERV directory create a text file called WCCMMUD.INI and set your setting in there. I allow anyone with the mudop key to perform all sysop functions and allow all users the sys map function. Here is my ini file.
LOGFILE=WCCMMUD.LOG
TRACK_LIMITED=1
LOG_SYSOP_COMMANDS=1
EXP_IN_TOPGANG=1
BLANK_LASTNAME_ALLOWED=0
SYS_LIGHTNING_KEY=mudop
SYS_STATUS_KEY=mudop
SYS_ADDLIFE_KEY=mudop
SYS_RETRAIN_KEY=mudop
SYS_ALIGNMENT_KEY=mudop
SYS_EDITEVIL_KEY=mudop
SYS_SPEAK_KEY=mudop
SYS_LISTUSER_KEY=mudop
SYS_LISTLIMIT_KEY=mudop
SYS_USERINFO_KEY=mudop
SYS_JAIL_KEY=mudop
SYS_CHANGE_KEY=mudop
SYS_BUFFERS_KEY=mudop
SYS_CLEARSUICIDE_KEY=mudop
SYS_REPORT_KEY=mudop
SYS_TOPTEN_KEY=mudop
SYS_DISBAND_KEY=mudop
SYS_RELOAD_KEY=mudop
SYS_VERIFY_KEY=mudop
SYS_GOTO_KEY=mudop
SYS_MAP_KEY=NORMAL
SYS_RESET_ROOMS=mudop
SYS_DISABLE_GANGS=mudop
Alo note that the log file does not truncate itself so you may want to edit your cleanup process to delete it every few days. I have mine set to delete every sunday at cleanup after the backup has fired. That way it is backed up before it is deleted.Hope this saves someone a few hours of figuring this out.
Larsen1906
Post by Larsen1906 »
Anyone know what the ini line is to add goto any rooms? conjure etc...
telnet tdrbbs.ddns.net
CODEC_OF_TWINKS=78
