New Edited Board Up Now!
BBS Advertisements. Post about your new/existing board.
nitebane21
Post by nitebane21 »
Address? Phoenix . Strangled . Net Port 23
Start date? 7/12/12
How many accounts? 2
PVP? Nope
When do I die? -200hp death, HOD has godheal as a room spell
Got sys commands? You have goto, map, add life and align. Don't abuse it.
When's cleanup? Cleanup at 3:00am Eastern. That's it for now unless more becomes necessary .
What's been edited?In a word, everything. Originally based on the experimental dats from the famous Lunar BBS, there are 24 races, 23 classes, tons of new items, tons of new mobs and areas.
Where are the dats? http://www.facebook.com/groups/255313784584408/
You gotta log into facebook. Sorry bout that, I'll figure out a better solution later. In the meantime, I'll be posting updates and collecting bug and balance fixes there.
*Disclaimer* This board's dats were given to me and I've spent tons of time going through them but I'm sure I've missed stuff. It was the 'test' dats, so there are going to be unbalanced things. This includes OP items, mobs with crazy exp/too little, too hard/easy bosses, weak/useless items & spells, etc etc. Don't abuse the stuff. Report it on the FB page.
radigast
Re: New Edited Board Up Now!
Post by radigast »
Board not up atm...
nitebane21
It is, try using port 23. It's prolly a firewall/router issue on my side
nitebane21
The dns needs to update since my IP changed. In the meantime you can use 71.164.78.4
nitebane21
Ok, I'm not great with networking stuff and I can't seem to get info from the dns to make it to my computer on the network. Any help would be great
radigast
Post by radigast »
The IP doesn't make it to an endpoint either. Are you using a firewall? You will have to route port 23 through your router/firewall to the computer hosting the BBS software. Ensure Windows Firewall (etc) is also configured to allow 23. Then finally make sure your BBS software is actually answering on port 23.
** How random that I posted at 10:39 both days.
nitebane21
I started a new thread here on the issue to try to keep this one fairly clean. http://www.mudinfo.net/viewtopic.php?f=44&t=1182 Any networking help or testing help would be greatly appreciated.
nitebane21
BOARD IS UP! YAY!
