connect rooms that overlap on the map
Posted: Mon Oct 07, 2019 3:05 am
by Necrosaro420
Been quite a while now since I have touched nightmare. Is there a way to get it to auto connect rooms that overlap on the map, as I am using map editor adding a new area?
Also, is there a way while using the map editor, to show more rooms at once? Would be nice to see a much larger area while I am adding rooms. Because as of now if I go say 6 or so rooms to the east, they start falling off the page, and kinda annoying.
Re: connect rooms that overlap on the map
Posted: Mon Oct 07, 2019 10:08 am
If the connecting room is close enough to your path it will see it and you need to switch to the connection option. But other then that no. And your stuck with the size in the map editor. Best option is to open the map window also.
