Reset
Moderator: DarkwoodBBS
Reset
I'm going to reset the board after about an 18 month run. I'll let some time go by for people to vote in the PVP / Accounts polls and then will announce launch date. The announcement of launch date will be at least one week before launch.
telnet://darkwood.ddns.net -- Mudrev with fixed and enhanced content, 25 level PVP
Information: http://www.mudinfo.net/viewforum.php?f=55
Re: Reset
Sounds awesome!
I'm mostly psyched how you've taken the time to fix the end-game gear textblocks. That was particularly frustrating before.
Silly question - do you know about the max spell damage, uhh... bug? Not sure it's a bug, but if you increase your characters +spdmg, it can result in the spell doing no damage at all. I wonder if it's similar to how too much charm will screw up shop pricing. Maybe I don't know what I'm talking about. It's been awhile. Just curious if that was something addressed or fixable?
Thanks for offering MudRev!
Re: Reset
I know the bug, but I think it is inside the hardcode of MUD itself rather than an issue with mudrev or ordinarily editable files. So eventually I think it gets to a point where people stop using mren (magical rending) if they are going to do room spells, because items/quest rewards/other spells already get them up to a safer 10-30%. I believe the issue is only triggered when room attacks are used.
I was able to work around the charm problem by making sure that all shop markups were sufficiently high. So I raised min/max charm across the board and now Charm-based casters can reach similar Spellcasting/Mana Regen to other classes.
Re: Reset
It looks like the voting is about done, so I'm going to set the date at 12/2, 30 level pvp, 3 simultaneous connections per IP.
