Is there a way to make a daily that required a different class on some kind of random or rotating basis? For instance, one day the mobs for the daily only spawn if a ranger is in the room. Maybe it's a boss that is insta-regen, but only if the right class is around. Alternately, it could be a boss or mob that spawns regularly but will give you a token on death only if you are the right class.
Any other ideas to spice up the daily quest medallion use that aren't as straight forward as adding higher level monsters for more exp?
High Level Daily Ideas
Moderator: BearFather
Re: High Level Daily Ideas
So at first yes it possible, but might take some work to make sure it can only happen once a day. But be easy to say if this class do this. Interesting idea, might have to work on that.
