Resources to edit 1.11i files(?)
Posted: Tue Jan 17, 2017 10:19 am
by MiOw
Whether by utility or otherwise, is there any direction available to edit 1.11i dats? Most specifically looking for the option to plug the bard cloak bug, Orfeo shop loophole, and surprise rounds. Learning as I go but appreciate any support available. Thanks!
Re: Resources to edit 1.11i files(?)
Posted: Tue Jan 17, 2017 10:32 pm
For the bard bug doesn't really matter what version you run, it's just missing a casting message to be defined, it points to a null message.
Orfeo shop issue, doesn't matter the version again you just raise his 100% to like 150%, it's just set too low for the charm that can be achieved.
Surprise round, well that is actually a dll issue. Good luck! Grab a wiki and cross your fingers it's the same location as it says.
Posted: Tue Jan 17, 2017 10:36 pm
by MiOw
BearFather wrote:For the bard bug doesn't really matter what version you run, it's just missing a casting message to be defined, it points to a null message.
The surprise round thing for sure I know that one is "deeper", but NMR does not read pre 1.11n dats (for good reason I suppose, can't expect Matt to do everything for us!) so is it otherwise a pretty simple thing to edit?
Posted: Tue Jan 17, 2017 10:46 pm
If you convert to the btreive dats system you can get tools to open and edit the dats for items,spells,mobs, etc. Not sure if it will still work following those steps.
Posted: Tue Jan 17, 2017 11:02 pm
Like I said on FB, 1.8 does support version 1.11i
Posted: Wed Jan 18, 2017 7:41 am
by MiOw
BearFather wrote:Like I said on FB, 1.8 does support version 1.11i
Aye, there are two versions of the app that are installed with the current release, one of which supports legacy versions. See the Readme included with the install.
Thank you, all!
