VOID BBS [ Home of AfterMUD ]
VOID BBS Changelog
More information on Mod 10: Eternity Awakened can be found here or by selecting NOTES from the main menu on the website.
Reminder: AfterMUD is still in Alpha, while it is the main MUD on this BBS it is very much still a WIP and should be treated as such.
This means development on AfterMUD will once again continue.
Downloads: AKiRA / VOIDBBS
P.S. I have also started updating the Wiki again...Updates
2024-10-22) AfterMUD has been updated to v0.3.0.
2024-08-01) VOID BBS goes down temporarily for relocation.
2024-01-11) AfterMUD has been updated to v0.2.2.
2023-10-14) AfterMUD has been updated to v0.2.1.
2023-09-01) Work on a new website as finished, check out at https://voidbbs.com.
2019-03-18) Website updated again, enter the realm now brings you to a guide on how to setup MegaMud. AfterMUD has been updated to version 0.2.0.
2019-03-11) The old sage has been spotted in the Dragon's Teeth Hills! Introduction of the level 40 daily quest.
2018-05-25) VOID BBS goes down for relocation (this took way too long I am sorry).
2018-03-26) Attention adventurer's of the Realm! An old sage has arrived in the Portal Room, talk to him to learn what he has to offer you. Daily quests have been added, these use direct database injections on cleanup to reset quest flags NO SPECIAL QUEST RESET ITEMS NEEDED!
2018-03-13) BBS has moved to a new domain voidbbs.com (old one still functions as well), website was also remade into an actual terminal. No longer must you click on things but you can also use your keyboard to navigate just like the BBS! BBS Advertisement image has been updated with new ANSI!
2018-02-25) MajorMUD and AfterMUD have been reset!
- AdmiralAcid
Re: VOID BBS [256 NODES | 250 MBIT | 64 GB]
It is really meant for MUDOPs however. Everyone gets MAP and GOTO, ELITE merely has REPORTS and LISTS as well and happens the be the class the sysop playing accounts have (i.e. mine).
Well I finally figured out a solution for all of the web stuff I have been working on for some time now!
All characters can now be clicked on, whether in the who's online or top adventurer's list, to get to that characters Hero Sheet. The hero sheet includes the "stat", "inventory" and "spells" game outputs for each character.
Background Info
Background Info
P.S. If anyone has any questions on setting up anything similar, feel free to ask!Getting the DATs from PSQL to MySQL was not as tricky as I thought it would be. Once I was able to do this I merely added some lines into my WGSCLEAN.BAT in order to copy the needed MajorMUD DATs over to the PSQL database folder every night and then run the PHP update script to resync from PSQL -> MySQL.
This allows me to have ingame data displayed on the website that is cache'd from the previous cleanup.
Sadly I cannot figure out how to use the live DATs cause when WGSERV is loaded the files are all locked, so I will settle with this for now. If anyone has any thoughts into this I'm all ears!
VOID BBS Update
Website has been revamped (same design basically) with terminal access! No longer are you restricted to using the mouse on the website, you can now use your keyboard just like a terminal!
I also bought a new domain to go along with the BBS, https://voidbbs.com/
WEBSITE TODO
1) Add in online information from finger server ✔
2) Add search capabilities for heroes and items ✔
3) Allow monster,shop and spell lookup and search
4) Flesh out captures & maps sections
5) AKiRA File Libraries (massive side-project) ✔
VOIDBBS is getting a new home hardware-wise and will be down for a few days, possibly a week total. Things were supposed to be sorted on time but something got messed up on my end. Apologies... no data has been lost however and should be back up as normal in a few days.
Hi, VOID is a really great BBS - brings back wonderful memories from when I used to play the game all the time.
Kudos on building a wonderful home for MajorMud.
Glad to hear new hardware is on its way - any updates on when you will restore the game?
Encourage all to come visit and make an account.
Changelog updated.
VOID BBS is running again in its new location with new hardware (sorry it took so long, I blame life).
BBS has been restored from exact state it was in when it went down.
The VOID BBS website has undergone major updates!
The TOP command has also been updated to retrieve its information from BTRIEVE, all xp/hr calculations are done on a 24 hour basis (ie. it averages from the last 24 hours, in between cleanups). You can also now show top lists for each class by using TOP <class>. Additionally there is now a top wealth list available with TOP WEALTH.
NOTE: Some of these are still a work-in-progress.
- Balthazar bot is no longer used. Information is pulled direct from BTRIEVE every night at cleanup.
- Users online is pulled from the finger daemon and cross-referenced with the BTRIEVE export.
- New Commands: HERO, ITEM, NPC and QUESTS.
- Updated Commands: TOP
