Adding a map to mud
Posted: Sun Feb 09, 2014 6:33 pm
So A friend of mine busted my balls to make a mud board. So after a couple weeks I started to tinker with editing. Well I want to make a new area now, So started in and said hey lets put all my edit's on a new map number so I can keep it clean. So did some test rooms to try out a few ideas, loaded up an bam I get this message when I try to enter:
Your sysop must purchase the appropriate addon (upgrade to the latest MajorMUD Version - most likely not available yet)
So played around couldn't figure it out. So other then putting it on a current map number, is there a way to activate a new map number?
Thanks
Re: Adding a map to mud
Posted: Fri Feb 14, 2014 8:05 am
You have to put the registration keys in. Either that or you didn't a patched/hacked dll installed.
Posted: Fri Feb 14, 2014 1:17 pm
Where would I put the reg keys in? Are you talking about mod 1-9? I got those keys in. And I didn't patch/hack the dll, that I know of. I just using nightmare to edit it.
Posted: Fri Feb 14, 2014 1:19 pm
BearFather wrote:Where would I put the reg keys in? Are you talking about mod 1-9? I got those keys in. And I didn't patch/hack the dll, that I know of. I just using nightmare to edit it.
Yes I was talking about the mods. That opens up maps 1-13(?) or something, can't recall exactly. May even just be 1-2, can't remember. But you need a hacked dll to use anything over the standard map numbers.
Posted: Thu Mar 27, 2014 5:36 pm
So what do you have to hack in the dll to allow different map #'s? Just curious. Is it worth the effort to do that?
Posted: Thu Mar 27, 2014 5:42 pm
The hacked Dlls out there already take care of it.
Posted: Fri Mar 28, 2014 9:39 am
That's the problem, I have found several of the patchers, but they seem to be the same. But they throw flags in my anti virus. Now not feeling very safe running something on a server that I have no clue what it is. That why I was asking what does it require to edit it. I have a hex editor, added a second mud server so had to switch from wcc to wbb. Mind you I'm no guru but I am pretty decent doing this shit.
All tho I see I will have to edit the dll to make more classes now, so is there a trusted link out there for this?
Posted: Fri Mar 28, 2014 10:43 am
It's not that simple. If you're concerned about the potential for a virus, download virtualbox and make yourself a sandbox (vm). Snapshot the vm, Put the dll on it, crack it, take it out. Close and restore snapshot.
