Ignition - Fresh Game Starting June 16th @ 8PM CST
Posted: Fri Jan 31, 2014 9:20 pm
by msdss
A fresh reset BBS is being brought up this coming Friday the 7th at 9PM.
The edits include:
Lair mod
Spell mod
5th weapon trader
double quest exp
small quest change mod
non-pvp
2 character limit
all rules and mods subject to change by community request
telnet address is:
ignition-bbs.us
Re: Ignition - Fresh Game Starting Feb 7th @ 9PM
Posted: Sun Feb 02, 2014 12:20 pm
by Corvette
What is wrong with the bard cloak? I have a bard on a board I'm playing. Should I not try to get that quest item if it causes a bug?
Posted: Sun Feb 02, 2014 2:19 pm
by msdss
There is a problem with how the cloak is set up in data.
It references spells and messages that aren't in the data tables.
As a result, when you use the cloak a crash can/will occur.
If the SysOp hasn't fixed the cloak then you can get it, but I wouldn't 'use' it.
It is easily fixable by either:
A) find the invalid data entries being referenced and put valid data in
B) change the data being referenced to valid data from another item
C) remove the references all together and turn it into just a basic cloak (if they do this, they should probably buff the cloak a little to make it worth getting).
Re: Ignition - Fresh Game Starting June 16th @ 8PM CST
Posted: Thu Jun 12, 2014 9:52 am
by msdss
Updated OP.
The board will be coming back online on Monday the 16th @ 8pm with a fresh reset.
