Dialsoft Control v5.62 + Keygen
msdss
Post by msdss »
Does anyone have the install / keygen for this?
I have v4.0 but I can't make it work (Doesn't let anyone get into MMUD).
I've searched the forums and apparently this isn't an issue in 5.62.
Also, if anyone has a decent set of gloves (I kind of loathe FU Globals) that would be spiffy as well.
Re: Dialsoft Control v5.62 + Keygen
you have to get into the setup for dialsoft and set the keys to normal thats why noone can get into mud dialsoft sets its own keys so if ya havn't made a menu tree option for dialsoft make one then go in and set keys
msdss
Post by msdss »
I made an online menu option (I couldn't find an actual setup or accounting menu). I went in and everywhere it mentioned a key, i set it to NORMAL, which is the key required to play. It still didn't let anyone in.
Do you know the specific menu option I need to set?
well check these options in securities and accounting under wccmmud
playkey: should be set to normal
savekey: should be set to normal
nodmokey: should be set to normal
in dialsoft control type config set all keys to normal but not the ley required for sysop access to control that should be set to sysop remember to choose save when ya exit
cjt
Post by cjt »
It won't work....there's something wrong with 4.0 that will always give you trouble. Send me a PM here with your email. I may have something of interest.
or just take dialsoft control out
msdss
Post by msdss »
That is what I'm doing until I can find a working solution.
cjt - pm sent.
msdss
Post by msdss »
Ping. If anyone has any links for a working version of this.
Or perhaps an alternative.
All I want to do is limit connections by IP address to make it easier to limit dupes. =/
