using light balls
using light balls
I am having no luck trying to get my Gypsy to use light ball in white dragons area. I cast illu. And just keep casting. No light. Any help would be great.
Re: using light balls
need more info....are you using the light ball after casting illu? If it's not lighting, use a message/response to 'use light ball^M' after you see the message that you've successfully casted Illumination.
Message/Response:
Use: Only for this Character
Message: You cast illuminate!
Response: use light ball^M
Effects: None
Action: Ignore
Find anywhere in text
Effects: None
Action: Ignore
