WG Access Violation Errors
...The ones that cause the bbs to crash and restart automatically. Which log file can I use to view the actual command prior to crash and/or crash report?
Re: WG Access Violation Errors
check your GALEXCEP.OUT text file located in your WGSERV directory, or whatever directory you installed the BBS into initially... this will be valid for WG 3.2 and possibly other versions... scrolling through this will show the time/date... servername/registration... user-id and channel causing it... the module name and input last entered... access violations will often be listed to tell you what type of btrieve error is associated with it...
-Matthew
-Matthew
MegaMUD BBS (ODS BBS)
Operation DataStorm BBS
http://bbs.MegaMUD.com
http://ods.ods.net
~ Since 1987 ~
http://ods.ods.net
~ Since 1987 ~
