Setting up a new board
Re: Setting up a new board
Yes the mud codes are based off the bbs codes. So will need to reg WG first then can generate mud codes.
Yes, a bad reg code for MMUD in the BBS settings, security and account if I remember right(?), will present the issue your experiencing. As for the WG code, I forget it’s limitations, but I always prefer entering it during install.
Once you have a working set I suggest saving them all in a .txt file. This makes re-installing a breeze, though now I just re-use my baseline .zip file of my WG folder.
synacktic
Post by synacktic »
I've been testing with WG2 (DOS) and I got a license violation error, what needs to be replaced / changed to fix that? Like which files does it keep track of that being an issue?
galden
Post by galden »
Apologies for bumping an old thread. I've hit the 161 license error with psql 9.5 after the trial server license expired.
Would anyone be able to point me in the direction of a permanent psql server key?
LordNikkon
Post by LordNikkon »
If someone is interested in setting up their own BBS, where might they have gotten a hold of one in the first place?
LordNikkon leaps in the air foolishly!
You can find WG on their site, they get free licenses. MM you find other ways and keygens out there.
