Scripting Programs
Gridlocked
Re: Scripting Programs
Post by Gridlocked »
https://www.facebook.com/photo.php?fbid ... =3&theater
Link shows it is installed.. with no way to uninstall per your instructions (I just go right to the control panel and search)
Gridlocked
So I downloaded an uninstaller program to see if I could find it..
It shows every program last 4 days except megammud on the list mudexplorer ect..
Gridlocked
By the way -- I had this all working running 6 characters for weeks until i tried installing the winter paths
Edit:
C:\Users\<user>\AppData\Local\VirtualStore\Windows\MegaMud.INI
change AutoLoadIni=1 to AutoLoadIni=0
Check the Directory= a valid place
\\HKEY_CURRENT_USER\Software\GWiz\MegaMud\Directory make sure that matches up.
Gridlocked
BearFather wrote: Thu Oct 18, 2018 9:58 am Edit:
That did it thanks man !!- That ini file also had the last character ini as an invalid path so i fixed it as well
Opps yeah meant to mention the lastchar lines, you want to blank those out too.
I'm glad it helped. Fixing that INI works wonders for many people's problems.
Karl
Post by Karl »
For anyone interested, here are the contents of my MegaMUD BBS Folder with the addresses and login automation already setup for every known working realm based on Anton's list from 10-12-2018.
MegaMUDBBSFolder10-20-18.zip
Unzip into MegaMUD BBS folder.
(18.8 KiB) Downloaded 1030 times
Gridlocked
I am playing on a moded board. There is an area with red griffons that put a poison on that does not show on the party window. The issue is that my party lead/tank just stops, wont move until its gone. I guess I could ignore it, but I would like to know is there a @poison that will trigger my two casters too cure him ? I tried setting commands to let the casters know.. didnt work
I did try just ignoring it. That works fine.. I paid a bit more attention and noticed it show the P in the window, however one cure poison doesn't do the trick. If one of my healers fails ect the party member still carries the poison. I am looking to see where the CURI spell is. I bet that would do the trick.
The warrior is Kang BTW.. Pisses me off to know end he is getting poisoned..
make an event to do st like every 10 seconds that should help
Gridlocked
Not sure how that would help. Even if the Tank does ST I do not know the trigger to get my casters to cast Cure. I can set up @poison but they say that is a bad command. tried @poisoned. I even tried @curemeyoupiecesofshit and nothing works.
I also tried creating a new message directly to the cater asking for a cure (cureme) with the casters response as cure <name> this is not like Telix.. I used to be able to write those scripts with my eyes closed. No matter what I try I cant get it to work.
Too bad there isnt a small window that has like 10 customizeable triggers simple shit like IF [Empty Box] - Then [Empty Box].
Using ^M I could get cures lol
Running my group to do the stealth quest. It is funny they get poisoned (regular poison) and the casters automatically cure. It seems to be so far the only cure/site ect that doesnt have an @trigger (rather than posting new messages just keep editing this one)
