Well I'll be dammed, it only gives it the stats if it's on the mob.BearFather wrote:Yes if you go kill that mob, that item will drop even at 1%.
Monster Attack Calculations / Formulas
Re: Monster Spells - Spell Attack Type -> Cast %
Re: Monster Attack Calculations / Formulas
So a mob might be more powerful when they have a nice item to drop. Hmm interesting, might explain why boss's can be a pain in the ass sometimes.
This restriction only seems to apply to limited items. On a mob with a 1% drop non-limited item, it gets the abilities every time following an offline recovery to wipe the active monster DB. My assumption is that when the monster is pulled from the known monster database into the active database, the limited item possibility is checked at that time, and then if the limited item is taken (or not chosen to drop at that particular time) then the item is removed from the "drops table" entirely, therefor not getting the abilities.
This is wrong (see my next post)
So if the item that give you +10 max dmg if it's limited only if it has it. But if it's not limited it will get the effect if he drops it or not?
Actually I was wrong. The mob I was using to test I had set a game limit on and had never been killed so he was set to drop all his loot on first kill. After I killed him and he dropped the item, his respawn did not hit me for the extra damage.
So I am trying to test between round casts now to make sure they work as I expected them to (and that they didn't have any affect on the mob's attacks [they don't seem to]).
Can anyone make any sense of this?
I'm no math expert, but looking at the numbers, it seems it peaks near the rounds they have. So the 4 rnd spell has a lot in 3-4 range. Where the 8 rnd hss a lot in 5-7 range. So the rnds might effect the outcome based on a sliding scale.syntax wrote:So I am trying to test between round casts now to make sure they work as I expected them to (and that they didn't have any affect on the mob's attacks [they don't seem to]).
Ya sure. Do you want to give us any more information, like what this test actually was or what you don't understand?syntax wrote:So I am trying to test between round casts now to make sure they work as I expected them to (and that they didn't have any affect on the mob's attacks [they don't seem to]).
I'm going to guess your confusion is based on spell rounds being 3 seconds, and a combat round being 5 seconds...
I didn't explain any more because I thought it was self explanitory to anyone that would've been able to help, and I was right, because you're exactly right as wellDeathCow wrote:Ya sure. Do you want to give us any more information, like what this test actually was or what you don't understand?syntax wrote:So I am trying to test between round casts now to make sure they work as I expected them to (and that they didn't have any affect on the mob's attacks [they don't seem to]).
Sorry, I didn't know if I was missing the confusing part or not.syntax wrote:I didn't explain any more because I thought it was self explanitory to anyone that would've been able to help, and I was right, because you're exactly right as wellDeathCow wrote:Ya sure. Do you want to give us any more information, like what this test actually was or what you don't understand?syntax wrote:So I am trying to test between round casts now to make sure they work as I expected them to (and that they didn't have any affect on the mob's attacks [they don't seem to]).
I'm going to guess your confusion is based on spell rounds being 3 seconds, and a combat round being 5 seconds...I didn't think of the spell rounds being different than the combat rounds and that explains it completely.
