v2.0.6 (10/10/2025)
-NEW: Hit Calculator improved and moved to its own window
-UP: Prot. from Evil implemented for monster damage vs character calculation
-UP: Option added to reset all character-related fields at once
-UP: Added sample weapon speed/dmg/swings to character builder
-UP: Level range on character builder now dynamic based on race stats
-UP: Tweak to one of the exp/hr models regarding mana regen
-UP: Cleaned up spell detail and added increases when global filter is off
-UP: Majority/Max Accuracy added to lair output
-UP: Monster regen time reduced from 1m30s to 30s for [GreaterMUD]
-FIX: Indication of level spell was casted (calculated) at in spell detail
-FIX: Attack/Combat setup screen showing @lvl for melee attacks
-FIX: +HitMagic from non-weapon sources not being properly applied
-FIX: Loremaster and Cartographer quest rewards swapped [GreaterMUD]
-FIX: Updated dodge formula for mob v player damage calc in [GreaterMUD]
-FIX: Ability search on Sundry tab not auto-completing
-Stealth Change: Damage Shield tracking removed on equipment tab and replaced with a +Hit Magic indicator
-Stealth Change #2 (because I forgot to put them in the notes): Dodge on EQ tab tooltip and character tab updated with more meaningful percentages
v2.0.7 (10/12/2025)
-UP: Added a "use" flag on inventory manager, use to open chests, read scrolls, etc
-UP: Spell detail columns will now show cast @lvl cap instead of @req level when global filter is off
-UP: Spell tab tweak: current char stats will only be utilized in table data when APPLYing filter w/global filter ON
-UP: Spellbook window will now only use current character stats with global filter on and matching class/magery
-FIX: Items not removed from saved list when equipped from item manager (setting)
-FIX: Weapon ability filter disabled when maximum effort or martial arts selected, but calc combat is off
-FIX: Prot. from Evil overvalued (x10!) in monster sim and monster dmg vs char calculations
v2.0.8 (10/12/2025)
-FIX: Missed a spot where the loaded character's stats were still effecting the spellbook output of another magery
