Page 2 of 2
Re: WG Access Violation Error - little help identifying cause?
Posted: Fri Jan 06, 2017 6:57 pm
by MiOw
syntax wrote:so you're saying the fix for this is to basically disable the forgive command? Which I assume you did through FU globals by assigning it to global commands? If so, how many variations of "forgive" did you need to add so I can add it to the instructions?
Let's say for now that I am reasonably confident that "rob" is not the board crashing command we thought it was while forgive seems reasonably confirmed under the right conditions. You would need to replace "forg", "forgi", "forgiv", and "forgive". When combined with "sha", "shar", and "share" I needed to find seven FU Globals slots to use. The ones I chose to use in order based on the minimum amount of noise they cause on the screen when executed are "rt" (read FU Grams to you), "rf" (from you), "td "(time of day simple), and "ask". As you know, there is the ";" and "=" version for each.
I hope that helps!
